OK, feature requests wanted
Sysprogs forums Forums WinCDEmu OK, feature requests wanted
Viewing 15 posts - 16 through 30 (of 51 total)
  • #3403
    It should normally support them. Can you share an example file that does not work?
    #3404
    Reith
    Contents of the cue sheet are here:
    http://pastebin.com/raw.php?i=96p8Vvxq
    The rest of the directory is the separate bin files (Track 01, Track 02, …, Track 23).
    #3405
    It’s great so far!
    I tested the vmnt.exe to create an ISO with the command line and also the batchmnt works fine, but I miss something.
    First of all: Why didn’t you release the Source Project Files?
    And you also did’nt modify/recreate the createiso parameter of vmnt.exe.
    When I type “vmnt.exe /createiso F” it opens up a graphical interface which wants me to chose a destination folder and a file name.
    I would like to have it without that interface so you can just generate it like this:
    /CreateISO F C:NewDirectoryFinalName.iso
    F = my physical drive
    C:NewDirectoryFinalName.iso = my destination path and filename
    #3406
    Basiz the output of the commandline in the portable version is in a wrong position,, check it out:
    The line “The driver is already installed” in theory must be:
    C:>PortableWinCDEmu-4.0-beta1.exe /install
    C:>
    P.S. Is not only that line, every output is in a wrong position ๐Ÿ˜‰
    #3411
    About the traslation, everyone with a resource editor without any programming knowledge can change the label of the button but there are some part missing in the DIALOG resource, like:
    or
    or Drive – Image of the Listview ( Basiz everyware ๐Ÿ˜† )
    Maybe other, dunno. If you add all the phrase in the DIALOG resource of the executable you don’t need to add any other saparate file for the language
    #3412
    I think that the “problem” with the language files isn’t anything that needs to be fixed asap.
    You just shouldn’t touch it if you want it to do its work.
    #3413
    Uh? Edit the resorce don’t compromize anything and there is nothing to fix. If basiz what to make the software multilanguage without additional file there are two ways, compile the software by ourself or edit the resource of the executable, that’s all.
    #3414
    I missunderstood that, sorry.
    Still, this is a feature request thread and that’s what I was expecting from your post.
    #3415
    The portable version can have the /CreateISO in the commandline? Thanks
    #3416
    So basiz, will the /CreateISO Parameter reach it into the command line ๐Ÿ˜€ ?
    #3417
    @bazis wrote:
    * Registry cleanup for portable driver uninstallation. Simply could not reproduce it. If you can share exact repro steps, I’ll look into it more
    Is easy to reproduce:
    a) Use a software for making a registry compare like Regshot
    b) Start WinCDEMU Portable and install the driver
    c) Mount an image <-- Important, i have Mount an ISO
    d) Unmount-Uninstall the driver
    e) Compare previous-after registry key with Regshot
    As you can see, the software leave traces, example here:
    Other keys was already posted, but just for complete information are:
    HKEY_LOCAL_MACHINESYSTEMControlSet001ServicesBazisPortableCDBus
    HKEY_LOCAL_MACHINESYSTEMCurrentControlSetServicesBazisPortableCDBus
    HKEY_LOCAL_MACHINESYSTEMControlSet001EnumRootLEGACY_BAZISPORTABLECDBUS
    HKEY_LOCAL_MACHINESYSTEMCurrentControlSetEnumRootLEGACY_BAZISPORTABLECDBUS
    My test machine is Windows 7 x64 on a clean VM
    #3418
    my request is… if you can improve the installer, in order to no install x64 files versions when you install in a x86 Windows version, because it cause some issues in event logs like:
    Activation context generation failed for "c:program filesWinCDEmuvmnt64.exe". Dependent Assembly Microsoft.Windows.Common-Controls,language="*",processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0" could not be found. Please use sxstrace.exe for detailed diagnosis.
    #3391
    steveo823
    @bazis wrote:
    Hi All,
    Looks like despite Windows 8 being able to mount ISO files natively, WinCDEmu is still popular. Hence I have no other choice than to respect our users and make a new release ๐Ÿ™‚
    Let’s make it a Christmas gift to the community ๐Ÿ™‚
    Please post requests for features/fixes in this thread. I cant’ promise anything massive as WinCDEmu is a side project for us, but I will be open to discussion.
    It would be great if we could right-click on a bootable USB drive and create an ISO like you can with a CD/DVD.
    Please…… ๐Ÿ™‚
    #3396
    bumping this.
    Bazis don’t let us down. I really need a UI-Less parameter with CreateISO.
    #3397
    feature request:
    – WinCDEmu support to mount ISO with CDAUDIO tracks.
