Howto: VisualGDB JTAG Debug soft Hazard3 RISC-V on ULX3S FPGA
Sysprogs forums › Forums › VisualGDB › Howto: VisualGDB JTAG Debug soft Hazard3 RISC-V on ULX3S FPGA
  • #37314
    gojimmypi
    I’ve created a custom Visual Studio VisualGDB project that can JTAG single-step apps on a soft FPGA RISC-V CPU, specifically Luke Wren’s Hazard3 (the same CPU used on the Raspberry Pi RP2350). Project and code files are here in the ulx3s-dev branch of my fork:
    https://github.com/gojimmypi/Hazard3/tree/ulx3s-dev/example_soc/synth/hazard3-fw
    Only the Debug settings for VisualGDB project have been configured.
    Assumes the repo was cloned from the C:\workspace\ directory, which will be /mnt/c/workspace/Hazard3 in WSL.
    Uses all open source tools in WSL: yosys, nextpnr, verilator, etc. in WSL
    Also assumes RISC-V toolchain installed in WSL for “Debug Settings – Debugger Path”:
    /opt/riscv/bin/riscv32-unknown-elf-gdb
    The exercise is specifically for HDMI Doom on the ULX3S and ULX4M, both with the Lattice ECP5 FPGA.
    See “Additional GDB Commands” for the shared hazard3-start from thehazard3-debug.gdb file.
    To start debugging, do NOT use “Debug – Start Debugging” with F5 (it won’t work).
    Instead use “Debug – Start Debugging with GDB”. Your OpenOCD should already be running:
    C:\workspace\hazard3\example_soc> path_to_your\openocd -d2 -f ulx3s-openocd.cfg
    The ULX3S can act as its own JTAG when using libusbK drivers, the ULX4M uses the Tigard JTAG.
    The “File Explorer” extension from Mads Kristensen will be helpful:
    https://marketplace.visualstudio.com/items?itemName=MadsKristensen.WorkflowBrowser
    as well as my Verilog Language Extension:
    https://marketplace.visualstudio.com/items?itemName=gojimmypi.gojimmypi-verilog-language-extension
    Readme files contain more details; feel free to reach out here or GitHub issues with questions.
    Enjoy!
    #37315
    Thanks for sharing this!
    #37367
    gojimmypi
    I’ve updated the repo with two separate VisualGDB project files:
    • Pure Windows-only RISC-V build (using xpack install in scripts directory)
    • Mixed build using WSL RISC-V toolchain
    https://github.com/ulx3s/Hazard3-Doom/tree/main/VisualGDB
    There’s a complete getting started here:
    https://ulx3s.github.io/ulx-doom/
