VirtualKD – Windows 10 will not boot up after debugging enabled
Sysprogs forums Forums VisualDDK/VirtualKD discussion VirtualKD – Windows 10 will not boot up after debugging enabled
  • This topic has 0 replies, 1 voice, and was last updated 8 years ago by vizy.
Viewing 1 post (of 1 total)
  • #20629
    vizy
    So I’ve installed on my Vmware Windows 10 64 bit machine with the vminstall.
    I then preformed:
    1. VM: Copy kdbazis.dll and kdpatch.sys to C:\Windows\System32\drivers\
    from virtualKD\target\x86 or x64.
    2. VM: Run kdpatch.reg.
    3. VM: Enable debug by serial port. (Use bcdedit or msconfig. Not vminstall.exe.)
    4. Host: Start kernel debug by Windbg with serial port, and run vmmon.exe/vmmon64.exe.
    After 5~10 seconds, Virtual Machine monitor starts transportation and debugging.
    https://sysprogs.com/w/forums/topic/virtualkd-windows-10/
    For enabling debugging I used:
    bcdedit /debug on
    bcdedit /dbgsettings serial debugport:1 from a cmd with admin privileges
    https://sysprogs.com/w/forums/reply/re-virtualbox-running-win7-wont-start-17/
    I also enabled test signing:
    Bcdedit.exe -set TESTSIGNING ON
    https://docs.microsoft.com/en-us/windows-hardware/drivers/install/the-testsigning-boot-configuration-option
    But every time right after I enable the debugging I’m getting the displayed image error. One time it even connected me to the Windbg session completely. It always pops up with debugging enabled. The VM just won’t boot up. Any help would be greatly appreciated, thanks!
