Sysprogs forums › Forums › VisualGDB › Missing hardware register definitions
- This topic has 7 replies, 3 voices, and was last updated 5 years, 1 month ago by
June 3, 2021 at 08:55 #30629
gfavier
ParticipantI’ve made an embedded project based on STM32CUBEMX (with STM32F051k8 processor) and cmake (I’ve used your tutorial https://visualgdb.com/tutorials/arm/stm32/cube/advanced/ ) . Every time I launch a debugger session, I have to import register svd definition manually. After a stop and a new start I need to do the same. Is there a way to save the .svd file position ?
The tab “Embedded Project” in VisualGDB Project Properties states : “This project is managed under the STM32CUBEMx tool…. ” and here isn’t the possibility to set the device by name
June 4, 2021 at 18:40 #30630support
No problem, please try this build: VisualGDB-5.6.1.4141.msi
VisualGDB will now correctly remember the manually specified register file for STM32CubeMX-based projects.
June 7, 2021 at 05:04 #30638gfavier
ParticipantPlease update your ninja.exe executable into .msi package; my PC suffers this problem:
ninja: error: FindFirstFileExA(c/:/users/{USERNAME}/): The filename, directory name, or volume label syntax is incorrect.
This is solved by using last ninja.exe <b>v1.10.2 </b>(under win64)
June 7, 2021 at 12:41 #30643support
KeymasterNo problem. We were delaying the update to Ninja 1.10, as it caused issues with NRFConnect projects. However, the latest NRFConnect release has solved them. Please try this build: VisualGDB-5.6.1.4142.msi
We will also include the latest Ninja version in the upcoming VisualGDB 5.6 Beta 2.
June 16, 2021 at 09:25 #30717tboutain
ParticipantI’m experiencing the same issue with a project imported from Atmel Start for SAME70 Xplained Pro (SAME70Q21B). I can load both the SVD from Atmel Studio Pack, as well as the XML downloaded from your website, but it remembers neither, even when I add either file to the Project settings under additional register definitions. I updated to the 5.6.1.4142 version with no change.
June 16, 2021 at 10:37 #30718support
No problem, we can help you. Please share the complete steps to reproduce the problem from scratch including all the relevant screenshots and we will help you fix it.
Also, please update your forum profile to match the email associated with your license key, or simply let us know your key via the support form.
July 12, 2021 at 17:17 #30947tboutain
ParticipantI have finally had to to revisit this issue and help you replicate it. I was able to fix it by adding copying the xml.gz file from the Atmel Arm Cortex BSP from VisualGDB website and added it to the ATMEL Start BSP folder, and then added the path to it under the MCUDefinitionFile property of the BSP.XML for the ATMEL Start BSP. I also added it to the CMakeLists.txt using
HWREGISTER_LIST_FILE same70b/DeviceDefinitions/SAME70N21.xmlI’m not 100% sure if both places are necessary or not, but it works now so I’m happy. Hopefully that will help anyone else trying to fix this issue as well.
July 14, 2021 at 12:23 #30955support
KeymasterThanks for sharing this. VisualGDB 5.6 Beta 4 should set HWREGISTER_LIST_FILE automatically. If you are using an older Beta, it might indeed fail to do so under some circumstances.
