Sysprogs forums › Forums › VisualGDB › VisualGDB + IAR: startup_stm32h743xx.s not included
- This topic has 4 replies, 2 voices, and was last updated 5 years, 8 months ago by
isigor.
June 22, 2020 at 15:43 #28473
isigor
ParticipantHi, I’m working with VisualGDB + IAR
I have started to compare map output file produced via IAR only and VisualGDB+IAR
For some reason vector_table if very different in size in both files, for example:
VisualGDB+IAR output
Section Kind Address Size Object
"A0": 0x40
.intvec ro code 0x800'0000 0x40 vector_table_M.o [7]
- 0x800'0040 0x40IAR output
"A0": 0x298
.intvec ro code 0x800'0000 0x298 startup_stm32h743xx.o [1]
- 0x800'0298 0x298I have noticed VisualGDB compilation ignores asm start up file, while IAR not,
and that leads to using default
vector_table_MHow can I force VisualGDB to compile this
startup_stm32h743xx.sfile, without it, vector table if different and it leads to HardFaultsIgor
June 23, 2020 at 02:26 #28486support
Normally, VisualGDB should build the .s files as long as they are included in the project.
If it doesn’t happen, please double-check that the file type is set to “C/C++ compiler” and it is not excluded from building:
If you can confirm that the file type is consistently set incorrectly (e.g. when importing some project), please let us know the steps to reproduce it and we should be able to fix it.
You must be logged in to view attached files.June 23, 2020 at 10:04 #28497isigor
ParticipantHi, thanks for your response, but I found the problem for this 🙂
(see attached image “Setting.png”)
I don’t know if it’s bug or feature but if you choose assembly file to Compile as “Plain C” or “C++” it just exclude the file from compilation and will cause the behavior I experienced before.
My whole project uses C++ and therefore I set it to Compile as C++, which means all file set to this setting automatically , so I had manually remove “Compile as C++” in startup_stm32h743xx.s to make it compile again, and it solved the problem.
Best regards
Igor
You must be logged in to view attached files.June 23, 2020 at 15:35 #28503support
KeymasterThanks for explaining this. We have updated VisualGDB to automatically reset the “Compile As” setting for assembly files in IAR projects. Please try this build: VisualGDB-5.5.7.3690.msi
June 24, 2020 at 15:13 #28510isigor
ParticipantThanks, 5,5,7,3690 seems to do the job
