Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › VirtualBox running Win7 won’t start
- This topic has 39 replies, 3 voices, and was last updated 14 years, 5 months ago by
jet_lee_spy.
June 1, 2011 at 17:42 #1523
ParticipantI can finally close this case, with the above fix it works fine with ICH9 and PCX chipsets, XP, W7 32/64 tested.
Greetings from Dresden to Kaiserslautern 😉
RonaldJune 26, 2011 at 17:16 #1524support
KeymasterFixed in VirtualKD 2.5.3/VisualDDK 1.5.3
Thanks to RonD for the solution!August 5, 2011 at 11:48 #1527Anonymous
ParticipantDoes any one has virtualKD x64 for VirtualBox 4.1? I have recompiled manually with VBOX 4.1 headers, but I still have error message
VirtualKD
VirtualKD cannot patch VirtualBox on-the-fly.
Please, shut down all your VMs, rename VBoxDD.dll
to VBoxDD0.dll and copy VBoxDD.dll from VirtualKD
package to VirtualBox directory.ОК
August 5, 2011 at 12:38 #1528Anonymous
VirtualKD
Also after installing vminstall in guest OS Win7 32bit, VM has crashes at boot time
August 6, 2011 at 11:18 #1529support
KeymasterPlease uninstall VirtualBox, remove all contents of OracleVirtualBox folder in Program Files, reinstall it and use the VBoxDD.dll from VirtualKD 2.5.4. It supports VirtualBox 4.1
August 7, 2011 at 20:07 #1526Anonymous
Thanks for reply, but this case does not helps 🙁
VirtualBox: 4.1.0
Guest OS: Windows 7 Ulyimate 32 bit, build 7601, service pack 1 (Debug)
Host OS: Windows 7 64 bit Home Ex, build 7601, service pack 1
Virtual KD: 2.5.4
WDK & debug tools: 7600.16385.1August 7, 2011 at 20:35 #1525Anonymous
ParticipantI have attached to vbox process and looked for loaded modules
VBoxC.dll C:Program FilesOracleVirtualBoxVBoxC.dll N/A N/A Symbols not loaded. 61 4.1.0.73009 19.07.2011 14:08 0000000003DD0000-0000000003FF6000* [11292] VirtualBox.exe: Native
VBoxDD.dll C:Program FilesOracleVirtualBoxVBoxDD.dll N/A N/A Symbols not loaded. 89 19.07.2011 14:08 000000000B7D0000-000000000BA39000* [11292] VirtualBox.exe: Native
VBoxDD2.dll C:Program FilesOracleVirtualBoxVBoxDD2.dll N/A N/A Symbols not loaded. 91 19.07.2011 14:08 000000000BA90000-000000000BABD000* [11292] VirtualBox.exe: Native
VBoxDDU.dll C:Program FilesOracleVirtualBoxVBoxDDU.dll N/A N/A Symbols not loaded. 90 19.07.2011 14:08 000000000BA40000-000000000BA90000* [11292] VirtualBox.exe: Native
….As you can see, no VBoxDD.dll loaded, but I placed DLL to C:Program FilesOracleVirtualBoxVBoxDD0.dll from C:UsersrootDownloadsvirtualkd 2.5.4VirtualKD-2.5.4VirtualBoxx64VBoxDD.dll
Md5 1A30E26B4FE413B196B4897169B46147 VBoxDD0.dllAugust 7, 2011 at 20:40 #1530support
KeymasterStop. Did you perform the installation correctly?
1. Rename “normal” VBoxDD.dll to VBoxDD0.dll
2. Copy VirtualKD’s VBoxDD.dll to VirtualBox directory (in place of the original VBoxDD.dll).
Both steps are vital. VirtualKD’s version of VBoxDD.dll should be used by VirtualBox instead of the original. However, it will redirect normal requests to the original DLL (it expects it to be called VBoxDD0.dll).August 7, 2011 at 20:48 #1531Anonymous
ParticipantThanks a lot, i’m confused in a manual. 😥
October 19, 2011 at 12:18 #1532jet_lee_spy
Participantdoes not work now in VBOX 4.1.4
