Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › Unable to create project
- This topic has 4 replies, 2 voices, and was last updated 16 years, 9 months ago by
sapero.
June 18, 2009 at 21:10 #77
sapero
ParticipantHello,
I have installed this plugin to my VS2005 (system drive C) and just confirmed the path to DDK 2600 (nonsystem drive D).
Launched the IDE, clicked new project, and got a STOP messagebox: WARNING! VisualDDK wizard was unable to find any DDK/WDK installed on your system. Please check your %DDKPATH% and %WDKPATH% environment variables.* DDKPATH environment variable is present in the environment block for Visual Studio process.
* all the build tools I have are working, even without reinstalling all the ddk’s after each system reinstallation.What do I miss? And why this plugin is searching instead just using the provided path?
I see something strange in the filemon logs:
00:04:42 devenv.exe:1856 QUERY INFORMATION D:WINDDK2600incddkWLHntddk.h PATH NOT FOUND 00:04:42 devenv.exe:1856 QUERY INFORMATION D:WINDDK2600incddkntddk.h FILE NOT FOUND 00:04:42 devenv.exe:1856 QUERY INFORMATION D:WINDDK2600incddkwdmWLHntddk.h PATH NOT FOUND 00:04:42 devenv.exe:1856 QUERY INFORMATION D:WINDDK2600incapintddk.h PATH NOT FOUND 00:04:42 devenv.exe:1856 QUERY INFORMATION D:WINDDK2600inccrtntddk.h FILE NOT FOUND 00:04:42 devenv.exe:1856 QUERY INFORMATION D:WINDDK2600incWLHntddk.h PATH NOT FOUND 00:04:42 devenv.exe:1856 QUERY INFORMATION D:WINDDK2600incddkWXPntddk.h SUCCESSThe /inc/ directory has only three subdirectories: crt, ddk, wxp
June 19, 2009 at 08:18 #1028support
KeymasterBefore creating a project, VisualDDK wizard searches for several header and library files in the DDK directory to detect correct include & lib paths for the project. You can see the search sequence in detail in the ProjectSettingsForm.cs file.
Basically, the following files are searched: ntddk.h, ntdef.h, wdm.h, excpt.h, guiddef.h, ntoskrnl.lib, hal.lib, int64.lib, ntstrsafe.lib, exsup.lib, amd64ntoskrnl.lib, amd64hal.lib, amd64ntstrsafe.lib. Could you please specify the paths for the files mentioned above on your system, so I can see, why VisualDDK does not find them.
It is very strange, that the wizard fails after successfully locating ntddk.h. Maybe, filemon shows failed attempt of locating other files (ntdef.h/etc)?
Additionally, you can recompile the DDKProjectWizard.sln solution and run the DDKProjectWizard2005 project (select devenv.exe as running executable). After setting breakpoint on TryCreateLocationInfoObject() method, you can see why exactly header search fails. Note that CreateLocationInfoObjects() calls this method four times for four different OSes (WLH/WXP/WNET/W2K), so, it is normally for some of them to fail, as not every DDK contains all four of them.June 19, 2009 at 09:13 #1029sapero
ParticipantThanks for your reply. I had to add the WINDDK6001.18000 directory as WDK path to get it working. Anyway there is the list of requested paths for 2600:
ntddk.h incddkwxp ntdef.h incwxp incddkwxp wdm.h incddkwdmwxp excpt.h inccrt guiddef.h incwxp ntoskrnl.lib libwxpi386 libwxpia64 hal.lib libwxpia64 libwxpi386 int64.lib libwxpi386 exsup.lib libwxpi386 amd64ntoskrnl.lib libwxpi386 libwxpia64 amd64hal.lib libwxpia64 libwxpi386 // but ntstrsafe.lib not found in 2600If you need the list of all the files from my 2600, I have created a zipped .lst file (view it in total commander) http://www.sendspace.com/file/sgwyg6
2600 is quite old, I think we have different releases.Maybe, filemon shows failed attempt of locating other files (ntdef.h/etc)?
Yes, the log above is not complete, I saw more fails on include and lib files.
June 19, 2009 at 09:18 #1030support
KeymasterCould you please test whether VisualDDK wizard handles DDK2600 correctly, if you create an empty ntstrsafe.lib file in LIB directory?
June 19, 2009 at 09:32 #1031sapero
ParticipantYes, the Wizard is opening, but ntstrsafe.lib must be in libwxpi386 directory. If ntstrsafe.lib exists in libwxpia64 only, 2600 is not visible in the versions combo box.
