Test program appears inconsistent
Sysprogs forums › Forums › VisualGDB › Test program appears inconsistent
  • #9708
    hfrmobile
    Creating new Unix project and try to deploy to Ubuntu (virtual) machine (VM). VM is configured properly and /tmp folder is accessible. Able to open shell SmarTTY from within Visual Studio/GDB.
    Test program appears inconsistent. Expected return code: 108. Actual return code: 127
    <span style=”text-decoration: underline;”>Detailed log:</span>
    Tool arguments:
    sh: /tmp/VisualGDB_ToolchainTestProgram_Deployed: not found
    #9709
    hfrmobile
    A closer look: connected to the wrong unix box ….
    But if I like to connect to the correct one over SSH:
    Cannot connect: No connection could be made because the target machine actively refused it <ip>:22
    #9716
    This means that your Linux machine is not running the OpenSSH server. If you are using a Debian-based distro, you can install it via the following command:
    sudo apt-get install openssh-server
