FreeRTOS debug with STMCubeMX projects
Sysprogs forums › Forums › VisualGDB › FreeRTOS debug with STMCubeMX projects
  • #35549
    shubaksa
    is it possible to use the FreeRTOS LiveWatch debugger view also with STMCubeMX generated projects? I was trying to do so, but only opening the tabs gives this error:
    VisualGDB version: 6.0.101.5147
    System.Exception: Missing queue type
    at PluginFreeRTOS.LiveWatch.NodeSource..ctor(ILiveWatchEngine engine)
    at PluginFreeRTOS.LiveWatch.FreeRTOSLiveWatchPlugin.CreateNodeSource(ILiveWatchEngine engine)
    at wc3.OnActivated()
    at VisualGDB.GUI.AdvancedAnalysis.LiveWatch.LiveWatchController.set_SelectedView(fg value)
    trace=[PluginFreeRTOS.LiveWatch.NodeSource..ctor:283, PluginFreeRTOS.LiveWatch.FreeRTOSLiveWatchPlugin.CreateNodeSource:6, wc3.OnActivated:11, VisualGDB.GUI.AdvancedAnalysis.LiveWatch.LiveWatchController.set_SelectedView:36]
    Am I missing something or is it just not compatible?
    Thank you,
    Stefan
    #35551
    Normally, it should work just fine. This specific error means that the debugging symbols in the executable do not contain the xQUEUE or Queue_t type, so VisualGDB does not have sufficient information to decode the state of the internal FreeRTOS structures.
    Please double-check that the debugged program is actually using FreeRTOS and has valid debugging symbols. Queue_t should normally be defined in queue.c. You can also double-check that the symbols reference it by checking sizeof(Queue_t) in the regular Watch window.
    #35587
    shubaksa
    I wasn’t able to fully track this issue down, but it works once I add at least one Queue via STM32CubeMX. Seems like there is some optimization magic happening in the background if you don’t do that.
    Thanks for pointing me in the right direction!
    #35589
    No worries. For what it’s worth, the FreeRTOS Live Watch functionality is implemented in a separate open-source plugin, so you can always tweak it if your setup involves something very specific that otherwise doesn’t work.
