Switch debugger between Linux and Windows
Sysprogs forums Forums VisualGDB Switch debugger between Linux and Windows
  • #9466
    illera88
    I have correctly setup VisualGDB to compile and run code compiled from my Windows system in Linux. But the code I’m writing is multiplatform (using #ifdef) and I would like to know it it works still fine in Windows. How can I tell VisualGDB to use the native Visual studio debugger instead of the already configured?
    #9467
    You may want to create a separate Linux and Windows configurations for that. Please check this tutorial: http://visualgdb.com/tutorials/porting/linux/
    #9503
    illera88
    I tried that but once I create the Linux one even when I select the “Debug” version it stills compiles it and run it in the remote system.
    I would like to use the VS compiler for the windows version.
    Regards
    #9505
    If you want to add a Windows configuration to an existing VisualGDB project, you can use the VS configuration manager to add it and then switch the configuration type from NMake to Application.
    Unless you are using the new MSBuild backend, VisualGDB configurations are normal NMake configurations (from VS point of view) that simply call VisualGDB.exe to do the actual build. If you change them back to normal Application configurations, VisualGDB won’t engage and you will be able to build an debug them normally.
    #9517
    illera88
    I got it.
    The trick was setting cmake as build option.
