VisualGDB is failing to create a very basic project with a single source file. Here’s the failure spew:
VisualGDB version: 5.2.15.1452
—————— System.UnauthorizedAccessException ——————
System.UnauthorizedAccessException: Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
at EnvDTE.SolutionClass.AddFromTemplate(String FileName, String Destination, String ProjectName, Boolean Exclusive)
at pb.a_2(Solution d, String c, String b, String a, Boolean e)
at o.a(String b, String a)
at yj.a_2(wo1 b, String a, String c)
at u9`1.Execute(Object b, Int32 c, Object[]& a, Object[]& e, wizardResult& d)
Repro steps:
In VS2017 start page click “Linux Project Wizard” under “Recent project templates:”
Select “Linux Project Wizard” in the “New Project” dialog and click OK
Select “Use GNU Make” then “next”
select “Build the project under Linux over network” – I have a remote machine specified and the SSH window comes up fine. The default toolchain is GCC
Select “next”
Select “Store source files on Windows computer” and “Upload modified sources to..”
select “finish”
Then you get the “Access is denied” message box.
