Select debugger via command line for unit testing in CICD
Sysprogs forums › Forums › VisualGDB › Select debugger via command line for unit testing in CICD
  • #26897
    Markg
    Hi
    We are using the unit testing via the command line, be we have multiple programming (segger j-link) probes connected. Is there a way to select a porobe via the command line? As an argument maybe?
    Regards,
    Mark
    #26900
    Normally, using the VisualGDB.exe /runtests <container> command line would automatically program the memory, run the tests and save the results.
    If you are not using the VisualGDB test frameworks, you can also use the VisualGDB.exe /launch <vgdbsettings file> syntax as an equivalent of the “run without debugging” command in Visual Studio.
    Finally, Segger J-Link might have its own set of commands for scripting FLASH memory programming. Feel free to double-check their documentation, it may contain some relevant examples.
