Problem with syntax coloring
Sysprogs forums › Forums › VisualGDB › Problem with syntax coloring
  • #32217
    parsec67
    I recently upgraded to a new PC, running VS 2022 17.0.5 Community and VisualGDB 5.6R2 build 4506.
    I have problems with certain text being coloring oddly in the VS text editor. Running with Dark theme, when I start entering e.g. a #define or function declaration the line I am editing will turn the background to near white, making it unreadable. Quick actions tooltip also pops up which may possibly be related to this. But I cannot find anywhere to change this setting? I only see this issue with VisualGDB, in regular Windows C/C++ projects coloring is fine. Choice of IntelliSense engine or formatting in VGDB project properties has no impact. Attached images demonstrate the problem.
    Also, despite having renewed my license and entered the key in December last year, About VisualGDB showed that my support period had expired. I’ve been in contact with support prior to switching PC and was told the old seat was deactivated. After re-entering the license key it now looks like it refreshed again and my support period is active, but why did it lose the activation to begin with?
    #32220
    Please refer to the following page for more details: https://visualgdb.com/documentation/colors/
    #32226
    parsec67
    Many thanks, that did the trick!
    Any idea why my license activation was reset?
    #32227
    Good to know it works.
    Regarding the activation, you can always reenter your key via Help->About VisualGDB in order to update its state.
