Live Watch Plugin FreeRTOS – Bug?
Sysprogs forums › Forums › VisualGDB › Live Watch Plugin FreeRTOS – Bug?
  • #37444
    AgAuCu_123
    I think I have encountered a problem with the FreeRTOS Plugin.
    If I define something like this the Queue is shown in the List of the Live Watch unter Synchronization Primitives:
    static osMessageQueueId_t queueTest
    But if I add the keyword volatile to the global variable it is not shown anymore in the list.
    My problem is that I have to do so, because it can be that my initialization of the queues are delayed and made in a task, therefore to assure that it stills works I have to use this keyword. But this shouldn’t really affect the tabs that are shown in the plugin, right?
    #37448
    Thanks for confirming your license. We have managed to reproduce the issue – it looks like a particular corner case with parsing a chain of DWARF debug type redirections.
    We have fixed it in the stand-alone build [CodeVROOM-0.8.0.368.exe]. It supports opening CMake-based VisualGDB projects out-of-the-box, and the FreeRTOS queues are shown under Debug->Windows->RTOS Objects. If it fixes the problem, we will run a few checks on the VisualGDB build from the same branch, and will publish the hotfix here.
    #37450
    AgAuCu_123
    okay, thank you very much. I appreciate the update.
    Then I’ll wait for the release in VisualGDB, as my personal preference is to continue working with Visual Studio rather than switching to CodeVROOM.
