ESP-IDF Intellisens
Sysprogs forums › Forums › VisualGDB › ESP-IDF Intellisens
  • #37496
    lkormos
    ESP32S3 using VS2022, VGDB5.6R9(4777), ESP-IDFV5.1, GCC12.2.0, GDB12.1 Revision1; 20230208. If i create a new project and covert it to c++ project and place <vector> or <deque>, it is recognised by intellisense and the project is building.
    ESP32P4 using VS2022, VGDB5.6R9(4777), ESP-IDFV5.4, GCC14.2.0, GDB14.2 Revision1. If i crete a new project and convert it to c++ project and place <vector> or <deque>, it is building but intellisense not working, properly red underlines white function names.
    Do you have any solution to this intellisense problem?
    László
    #37497
    VisualGDB 5.6 is very old and is no longer maintained. Please make sure you use the latest VisualGDB 6.1.
    You can also try using CodeVROOM – the stand-alone cross-platform VisualGDB port that supports ESP-IDF on Windows, Linux and Mac.
