Sysprogs forums › Forums › VisualGDB › NucleoF767ZI Cannot upload or debug Arduino sketch
- This topic has 5 replies, 2 voices, and was last updated 6 years, 8 months ago by
January 10, 2020 at 19:02 #27016
indridkold
ParticipantI’m testing a fresh install of VisualGDB on VS2019 and cannot upload to my Nucleo-F767ZI card. I create the project with the settings shown in Attachement_1. I can successfully test the ST-Link v2.1 connection, results shown in Attachment 2. The program compiles and I attempt to upload the sketch. The upload fails and a popup appears, popup shown in Attachment 3. It seems vGDB is attempting a mass storage upload to NODE_F207ZG. The mass storage name of the connected card is NODE_F767ZI, as shown in Attachement 4. If I drag the .bin file to the F767 it copies but does not run so it may not actually be built correctly. Any assistance appreciated, IK
You must be logged in to view attached files.January 10, 2020 at 19:03 #27021support
It looks like some issue with the drivers or Arduino tools. Please try checking if you can program the board using Arduino IDE. If yes, we can help you achieve the same results with VisualGDB. If not, please try posting on Arduino forums.
January 10, 2020 at 19:38 #27022indridkold
ParticipantThanks for the quick response. The sketch does compile and upload using Arduino, the output is attached. I’ve set the upload to use the STMCubeProgrammer(SWD). I would prefer to use that for vGDB also. An image of the Arduino settings is also attached. IK
You must be logged in to view attached files.January 10, 2020 at 20:04 #27024support
KeymasterSorry, it looks like the file did not get uploaded properly. Would you mind compressing it and trying again?
Also please double-check that you have selected the same upload method via VisualGDB Project Properties -> Project Settings (please attach a screenshot if you are not sure).
January 10, 2020 at 20:36 #27025indridkold
ParticipantGreat, working now. I opened the VisualGDB project properties (which I had not found before) and the settings were incorrect. An image is attached. Once I set ‘Board part number’ to Nucleo F767ZI and the upload method to STM32CubeProgrammer everything uploaded fine and I was able to start a debug session. The board part number is not set during project creation and I didn’t realize I had to set it in Project Properties. All good now. Thanks for your help, IK
You must be logged in to view attached files.January 10, 2020 at 20:38 #27027support
KeymasterNo worries and good to know it works. The advanced target-specific settings indeed only appear once the project has been created (and VisualGDB got a chance to query them from the Arduino tools).
If you encounter further issues, feel free to start another thread and we will be happy to help.
