thanks for the prompt response! I updated to the file you linked above and I can see the new option in the “Librarian” page. The behaviour has changed but now it returns an error running the command:
c:\programdata\gnu tools arm embedded\bin\../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/ar.exe: invalid option — @
I can see it use the gcc.ar.exe now:
C:\ProgramData\GNU Tools ARM Embedded\bin\arm-none-eabi-gcc-ar.exe -r ../../VisualGDB/Debug/mylib.a {lots of .o files}
If I actually copy the gcc-ar.exe line that appears above the error I just pasted and run it from the command line it executes successfully, so I am not sure what is going wrong. Do you need some more info from me? This also occurs if I switch to the sysgcc that you can download via VisualGDB.
This reply was modified 8 years, 6 months ago by
barak.
