Missing 'Convert to a Stand-alone Framework'
Sysprogs forums › Forums › VisualGDB › Missing 'Convert to a Stand-alone Framework'
  • #34867
    neon
    Ive tried to follow the tutorial https://visualgdb.com/tutorials/arm/cmake/standalone/frameworks/
    But couldnt find “Convert to a Stand-alone Framework” command from the framework context menu referenced in step 10.
    Can someone help me?
    Thank you!
    #34870
    It’s hard to say why exactly the command would not be visible. Perhaps, you selected a different project type, or are not using the Custom edition.
    If you could attach a screenshot of the entire uncropped Visual Studio window and the context menu with the missing command, we might be able to suggest something.
    #34874
    neon
    So I need the custom edition for doing that? I didnt know that…
    But anyway I will write my CMakeLists and stuff in a general way now und not relying on add_bsp_executable and friends just to be more flexible in the future.
    #34875
    It’s a part of the project template mechanism, so the GUI for managing it is indeed only available starting from the Custom edition.
    That said, the add_bsp_executable() and related commands work with all editions, are fully documented and are expected to remain fully backward-compatible in the future VisualGDB releases. So you can still rely on the VisualGDB’s CMake framework as long as you define the frameworks manually.
