same to me (Raspberry Project). All include paths are set, files are there, but clang ignores all of them, build works. Adding missing headers by the ‘add-wizzard’ (screenshot) results in error …
(the german text in the msgbox means: ‘Value may not be NULL. Name of parameter: path1’)
i just found out that it works as MSBuild and CMake in case of unchecking ‘Use the advanced CMake Subsystem’ and not using ssh, so it may be a problem related to using direct ssh access.
Sorry, this is showing the flags for the main source file, but not for the project itself. Please click at the project name and then copy the CXXFLAGS.
Also the diagnostics console shows that the Clang server process has terminated. Was this caused by reopening the project, or does this message seem to occur randomly?
