How to output the compiled assembly?
Sysprogs forums › Forums › VisualGDB › How to output the compiled assembly?
  • #8475
    CurtisHx
    How I list the assembly from the compiler?  I tried adding the -S option to the CCFAGS settings under VisualGDB Project Properties-> Makefile settings, but only the object files wind up in the Debug folder.
    #8476
    The easiest way to do that is to copy the build command line from the Output window, replace “-c” with “-S” and “-o <object.o>” with “-o <output.S>” and run it manually from the Command Line Prompt. Then the assembly output will be saved to <output.S>.
    #8482
    CurtisHx
    Is there a better way to do it?  I would like to configure the project to output the assembly as well as object files for all of the compiled files during a build.
    #8484
    Yes, you can edit the Makefile as follows:
    #VisualGDB: FileSpecificTemplates        #<--- VisualGDB will use the following lines to define rules for source files in subdirectories
    $(BINARYDIR)/%.o : %.cpp $(all_make_files) |$(BINARYDIR)
        $(CXX) $(CXXFLAGS) -c $< -o $@ -MD -MF $(@:.o=.dep)
        $(CXX) $(CXXFLAGS) -S $< -o $(@:.o=.S)
    Then modify the SOURCEFILES line so that VisualGDB regenerates the file-specific templates. This should start generating a .S file for each source file.
    #8486
    CurtisHx
    Nice.  That’s exactly what I was looking for.  I’m still fairly new to gcc and makefiles.
