CPP newbe
Sysprogs forums Forums VisualGDB CPP newbe
  • #11449
    donvukovic
    I have got the ESP32DEMO working with the help of folks here. Thank You.
    I followed the flow in ../tutorials/esp32 but used the example for wpa2_enterprise.
    There is a compiler error that I do not understand:
    Severity    Code    Description    Project    File    Line    Suppression State
    Error        undefined reference to `emac_send_pause_zero_frame_enable’    wpa2    C:\Users\Donald\Documents\visualStudio2017\wpa2\wpa2\VisualGDB\Debug\emac_main.o    1
    Error        undefined reference to `emac_send_pause_zero_frame_enable’    wpa2    C:\SysGCC\esp32\esp32-bsp\esp-idf\components\ethernet\emac_main.c    600
    Error        ld returned 1 exit status    wpa2    C:\Users\Donald\Documents\visualStudio2017\wpa2\wpa2\collect2    1
    The editor can find the inline function call but the compiler can not.
    Can someone help a newbe.
    Thank You
    #11450
    donvukovic
    Sorry, the example HTTP Server.
    I just called it wpa2_enterprise, without knowing better.
    #11454
    Looks like you are missing some source files or libraries. Please try searching the ESP-IDF tree for .c and .a files containing the ‘emac_send_pause_zero_frame_enable' text and then try adding them to your project.
    #11857
    ibrahimdanish
    I got the same error. It looked like an inline issue. The inline function is located in \SysGCC\esp32\esp32-bsp\esp-idf\components\ethernet\emac_dev.h but the linker couldn’t find it. Can be fixed by setting InlineFunctions to Yes in Project->Properties->C/C++->Optimization->InlineFunctions .
    #11861
    This is a separate issue. Generally ESP32 IDF does not work when built with the disabled optimization (-O0) and requires changing the optimization level to at least -Og. This also fixes the inline functions.
