Could not find mmal libraries
Sysprogs forums › Forums › VisualGDB › Could not find mmal libraries
  • #9416
    DiederikRhee
    Hi everybody,
    I am following the raspberry pi camera tutorial. I am stuck by step 20. I always get this error:
    1>—— Build started: Project: PiCamera, Configuration: Debug Win32 ——
    1> VisualGDB: Run “D:\Program Files (x86)\CMake 2.8\bin\cmake.exe -DCMAKE_SYSTEM_PROCESSOR=armv71 -G “Unix Makefiles” -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_COLOR_MAKEFILE=OFF .. -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCMAKE_TOOLCHAIN_FILE=toolchain-Debug.cmake -DCMAKE_MAKE_PROGRAM=”C:/SysGCC/raspberry/bin/make.exe”” in directory “D:\documents\projectsPPII\PiCamera\..\..\..\Downloads\raspicam-0.1.3\raspicam-0.1.3/Debug” on local computer
    1> CMake Error at CMakeLists.txt:45 (MESSAGE):
    1> — Configuring incomplete, errors occurred!
    1> Could not find mmal libraries
    1>
    1>
    1> ————————————————————-
    1> Command exited with code 1
    1> Executable: D:\Program Files (x86)\CMake 2.8\bin\cmake.exe
    1> Arguments: -DCMAKE_SYSTEM_PROCESSOR=armv71 -G “Unix Makefiles” -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_COLOR_MAKEFILE=OFF .. -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCMAKE_TOOLCHAIN_FILE=toolchain-Debug.cmake -DCMAKE_MAKE_PROGRAM=”C:/SysGCC/raspberry/bin/make.exe”
    1> Directory: D:\documents\projectsPPII\PiCamera\..\..\..\Downloads\raspicam-0.1.3\raspicam-0.1.3/Debug
    1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets(37,5): error MSB3073: The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “D:\documents\projectsPPII\PiCamera\PiCamera.vcxproj” “/solution:D:\documents\projectsPPII\RaspberryCameraTestje\RaspberryCameraTestje.sln” “/config:Debug” “/platform:Win32″” exited with code 1.
    Today I updated to version 5.2 without any succes. Who can help me out? I want to build a c# opencv project with raspberry pi 2 and the raspberry pi camera module. I want to remote debug from my windows computer.
    <div>Best regards,</div>
    <div>Diederik van der Rhee</div>
    #9453
    This could be caused by a problem that was solved in VisualGDB 5.2. Please try updating to it and resynchronize your toolchain sysroot.
