Hi, I’m trying to get batchmnt working with a small batch file used in XBMC to mount and ISO, which will then be played by PowerDVD. I’m using the following command syntax:
"C:Program Files (x86)WinCDEmubatchmnt.exe" %1 V /wait
This works perfectly when the ISO is a local file, residing on my HDD – the image is mounted in an appropriate drive type (DVD drive for DVD discs, BD drive for BD discs). However, if the ISO file is on the network, using batchmnt, I get a device of “CD Drive” – which seems to interfere w/ PowerDVD reading the disc. (at least for DVD discs; BD seems to work ok, strangely).
If instead of batchmnt, I use the regular context menu to “Select drive letter and mount” with a network ISO, the default drive type is correctly selected: DVD or BD depending on the image. When this image is mounted this way, the PowerDVD program has no issues reading the disc at all.
So, how can I force batchmnt to emulate a certain type of drive hardware (wouldn’t BD-ROM be a better default than CD Drive)? Or is there a way to fix this issue some other way? Perhaps it’s a bug? Thanks for your input!
(I realize that it may actually be an issue with PowerDVD more than WinCDEmu, but, seriously, what’s the chance of getting a useful response from them? 😉 )
