Annoying behavior
Sysprogs forums › Forums › VisualGDB › Annoying behavior
  • #22520
    sidprice
    Hi, each time a debug session is started the GDB Session windows is activated, if one is using tracepoints this requires selection of the Output view and then selection of Debug output at the start of every session. I would expect that if the Output window was the active window with Debug output displayed when a debug session is ended, then that would be the start condition for the next debug session for the same project.
    Is there some way to get this happen?
    Sid
    #22524
    Yes, please use the “Don’t Activate GDB Session Window” setting under Tools->Options->VisualGDB.
    #22530
    sidprice
    Very good,thank you for the great support,
    Sid
