VisualGDB.exe /build ignoring /config
Sysprogs forums › Forums › VisualGDB › VisualGDB.exe /build ignoring /config
  • #25144
    sorenml
    I am trying to automate my build process and everything is going great so far besides the fact, that I cannot get VisualGDB to build the project with command line with any other config than Debug.
    I am trying commands like: VisualGdb.exe /build /config:Deploy MyProject.vgdbproj
    It builds but I always get this in the output: “VisualGDB: Warning: No configuration specified, defaulting to ‘Debug’. Use ‘/config:<name>’ to override.”
    Any idea how to get this fixed?
    /Søren
    #25145
    This might be by design for some project types (e.g. Arduino or Mbed) that only support a fixed set of 2 configurations (Debug/Release).
    If you could attach a .vgdbproj file that triggers this, we should be able to tell more.
    #25147
    sorenml
    I am running it directly from cmd and I have tried with /config:Release as well without luck. What i really need is only Debug and Release, so i can reduce logging in production. I have added the project file below, but removed the VirtualSourceFolder
    <?xml version=”1.0″?>
    <VisualGDBProjectSettings2 xmlns:xsi=”http://www.w3.org/2001/XMLSchema-instance&#8221; xmlns:xsd=”http://www.w3.org/2001/XMLSchema”&gt;
    <ConfigurationName>Debug</ConfigurationName>
    <Project xsi:type=”com.visualgdb.project.external.esp-idf”>
    <CustomSourceDirectories>
    <Directories/>
    <PathStyle>Unknown</PathStyle>
    </CustomSourceDirectories>
    <ProjectModeSettings>
    <ProjectGUID>7674c0c4-703c-4b6f-86bb-0a7a422ba88b</ProjectGUID>
    <GroupSourcesByTypes>true</GroupSourcesByTypes>
    <GroupSourcesByPaths>true</GroupSourcesByPaths>
    <HeaderScanMode>SourceDirs</HeaderScanMode>
    </ProjectModeSettings>
    </Project>
    <Build xsi:type=”com.visualgdb.build.cmake”>
    <ToolchainID>
    <ID>com.visualgdb.xtensa-esp32-elf</ID>
    <Version>
    <GCC>5.2.0</GCC>
    <GDB>7.10</GDB>
    <Revision>16</Revision>
    </Version>
    </ToolchainID>
    <RelativeSourceDirectory/>
    <ConfigurationType>DEBUG</ConfigurationType>
    <BinaryDirectory>VisualGDB/$(ConfigurationName)</BinaryDirectory>
    <MakeCommandTemplate>
    <SkipWhenRunningCommandList>false</SkipWhenRunningCommandList>
    <RemoteHost>
    <HostName>BuildMachine</HostName>
    <Transport>BuiltinShortcut</Transport>
    </RemoteHost>
    <Command>$(VISUALGDB_DIR)/ninja.exe</Command>
    <Arguments/>
    <WorkingDirectory>$(BuildDir)</WorkingDirectory>
    <BackgroundMode xsi:nil=”true”/>
    </MakeCommandTemplate>
    <CMakeCommand>
    <RemoteHost>
    </RemoteHost>
    <Command>$(SYSPROGS_CMAKE_PATH)</Command>
    </CMakeCommand>
    <UpdateSourcesInCMakeFile>true</UpdateSourcesInCMakeFile>
    <ExportCompileCommands>false</ExportCompileCommands>
    <DisableToolchainFile>false</DisableToolchainFile>
    <ExtraConfigurationVariables>
    <string>-Werror=switch</string>
    </ExtraConfigurationVariables>
    <CMakeMakefileType>Ninja</CMakeMakefileType>
    <DeployAsRoot>false</DeployAsRoot>
    <ProjectItemSettings>
    <GroupTargetsByPaths>true</GroupTargetsByPaths>
    <AutoRefreshProject>true</AutoRefreshProject>
    <SortTargetsByName>true</SortTargetsByName>
    <UseCMakeUpToDateCheck>false</UseCMakeUpToDateCheck>
    <RedundantTargetMode>HideOuterProjectTargets</RedundantTargetMode>
    <SortSourcesByName>true</SortSourcesByName>
    <BuildAllTargetsInSubdir>false</BuildAllTargetsInSubdir>
    <FoldSingleItemPathLevels>true</FoldSingleItemPathLevels>
    </ProjectItemSettings>
    <TargetSpecificSettings>
    <CMakeTargetSpecificSettings>
    <TargetID>main</TargetID>
    <Debug/>
    <Deployment>
    <Mode>Auto</Mode>
    <DeployIfNotSpecificallyReferenced>false</DeployIfNotSpecificallyReferenced>
    <DoNotDeployVersionedBinaries>false</DoNotDeployVersionedBinaries>
    </Deployment>
    <SetLDLibraryPathFromDependentArtifacts>true</SetLDLibraryPathFromDependentArtifacts>
    <ProjectGUID>72141596-a778-45ff-8365-c98e9be05c99</ProjectGUID>
    <VirtualFolders/>
    <ConfigurationNameCase>Upper</ConfigurationNameCase>
    <DefaultHeaderDiscoveryMode>HeaderDirectoryAndSubdirectories</DefaultHeaderDiscoveryMode>
    <ESPIDFExtension>
    <IDFCheckout>
    <Version>release/v3.2</Version>
    <Subdirectory>esp-idf/v3.2</Subdirectory>
    </IDFCheckout>
    </ESPIDFExtension>
    </Build>
    <CustomBuild>
    <PreSyncActions/>
    <PreBuildActions/>
    <PostBuildActions/>
    <PreCleanActions/>
    <PostCleanActions/>
    </CustomBuild>
    <CustomDebug>
    <PreDebugActions/>
    <PostDebugActions/>
    <DebugStopActions/>
    <BreakMode>Default</BreakMode>
    </CustomDebug>
    <CustomShortcuts>
    <Shortcuts/>
    <ShowMessageAfterExecuting>true</ShowMessageAfterExecuting>
    </CustomShortcuts>
    <UserDefinedVariables/>
    <ImportedPropertySheets/>
    <CodeSense>
    <Enabled>True</Enabled>
    <CFLAGS>-Wno-switch</CFLAGS>
    <CXXFLAGS>-Wno-switch</CXXFLAGS>
    <ExtraSettings>
    <HideErrorsInSystemHeaders>true</HideErrorsInSystemHeaders>
    <SupportLightweightReferenceAnalysis>true</SupportLightweightReferenceAnalysis>
    <DiscoverySettings>
    <Mode>Silent</Mode>
    <SearchInProjectDir>true</SearchInProjectDir>
    <SearchInSourceDirs>true</SearchInSourceDirs>
    <SearchInIncludeSubdirs>true</SearchInIncludeSubdirs>
    <ExtraSearchDirs>
    <string>C:\SysGCC\esp32\opt\xtensa-esp32-elf\xtensa-esp32-elf\include\c++\5.2.0</string>
    <string>C:\SysGCC\esp32\opt\xtensa-esp32-elf\lib\gcc\xtensa-esp32-elf\5.2.0\include</string>
    </ExtraSearchDirs>
    </DiscoverySettings>
    <CheckForClangFormatFiles>true</CheckForClangFormatFiles>
    <FormattingEngine>ClangFormat</FormattingEngine>
    </ExtraSettings>
    <CodeAnalyzerSettings>
    <Enabled>false</Enabled>
    </CodeAnalyzerSettings>
    </CodeSense>
    <Configurations>
    <VisualGDBConfiguration>
    <Name>Debug</Name>
    <BuildSettingsExtension xsi:type=”com.visualgdb.build.external.esp-idf.extension”>
    <OutputSubdirectory>Debug</OutputSubdirectory>
    <SDKConfigFile>sdkconfig-debug</SDKConfigFile>
    <EnableVerboseBuild>false</EnableVerboseBuild>
    </BuildSettingsExtension>
    </VisualGDBConfiguration>
    <Name>Release</Name>
    <OutputSubdirectory>Release</OutputSubdirectory>
    <SDKConfigFile>sdkconfig-release</SDKConfigFile>
    </Configurations>
    <ProgramArgumentsSuggestions/>
    <Debug xsi:type=”com.visualgdb.debug.embedded”>
    <AdditionalStartupCommands/>
    <AdditionalGDBSettings>
    <Features>
    <DisableAutoDetection>false</DisableAutoDetection>
    <UseFrameParameter>false</UseFrameParameter>
    <SimpleValuesFlagSupported>false</SimpleValuesFlagSupported>
    <ListLocalsSupported>false</ListLocalsSupported>
    <ByteLevelMemoryCommandsAvailable>false</ByteLevelMemoryCommandsAvailable>
    <ThreadInfoSupported>false</ThreadInfoSupported>
    <PendingBreakpointsSupported>false</PendingBreakpointsSupported>
    <SupportTargetCommand>false</SupportTargetCommand>
    <ReliableBreakpointNotifications>false</ReliableBreakpointNotifications>
    </Features>
    <EnableSmartStepping>false</EnableSmartStepping>
    <FilterSpuriousStoppedNotifications>false</FilterSpuriousStoppedNotifications>
    <ForceSingleThreadedMode>false</ForceSingleThreadedMode>
    <UseAppleExtensions>false</UseAppleExtensions>
    <CanAcceptCommandsWhileRunning>false</CanAcceptCommandsWhileRunning>
    <MakeLogFile>true</MakeLogFile>
    <IgnoreModuleEventsWhileStepping>true</IgnoreModuleEventsWhileStepping>
    <UseRelativePathsOnly>false</UseRelativePathsOnly>
    <ExitAction>None</ExitAction>
    <DisableDisassembly>false</DisableDisassembly>
    <ExamineMemoryWithXCommand>false</ExamineMemoryWithXCommand>
    <StepIntoNewInstanceEntry>app_main</StepIntoNewInstanceEntry>
    <ExamineRegistersInRawFormat>true</ExamineRegistersInRawFormat>
    <DisableSignals>false</DisableSignals>
    <EnableAsyncExecutionMode>false</EnableAsyncExecutionMode>
    <EnableNonStopMode>false</EnableNonStopMode>
    <MaxBreakpointLimit>0</MaxBreakpointLimit>
    </AdditionalGDBSettings>
    <DebugMethod>
    <ID>openocd</ID>
    <Configuration xsi:type=”com.visualgdb.edp.openocd.settings.esp32″>
    <CommandLine>-f interface/ftdi/um232h.cfg -f target/esp32.cfg -c “adapter_khz 3000″</CommandLine>
    <ExtraParameters>
    <Frequency xsi:nil=”true”/>
    <BoostedFrequency xsi:nil=”true”/>
    <ConnectUnderReset>false</ConnectUnderReset>
    </ExtraParameters>
    <LoadProgressGUIThreshold>131072</LoadProgressGUIThreshold>
    <ProgramMode>Enabled</ProgramMode>
    <StartupCommands>
    <string>set remotetimeout 60</string>
    <string>target remote :$$SYS:GDB_PORT$$</string>
    <string>mon gdb_breakpoint_override hard</string>
    <string>mon reset halt</string>
    <string>load</string>
    </StartupCommands>
    <ProgramFLASHUsingExternalTool>false</ProgramFLASHUsingExternalTool>
    <PreferredGDBPort>0</PreferredGDBPort>
    <PreferredTelnetPort>0</PreferredTelnetPort>
    <SuggestionLogicRevision>0</SuggestionLogicRevision>
    <CheckFLASHSize>true</CheckFLASHSize>
    <FLASHSettings>
    <Size>size2MB</Size>
    <Frequency>freq40M</Frequency>
    <Mode>DIO</Mode>
    </FLASHSettings>
    <PatchBootloader>true</PatchBootloader>
    </Configuration>
    </DebugMethod>
    <AutoDetectRTOS>true</AutoDetectRTOS>
    <SemihostingSupport>Auto</SemihostingSupport>
    <SemihostingPollingDelay>0</SemihostingPollingDelay>
    <StepIntoEntryPoint>false</StepIntoEntryPoint>
    <ReloadFirmwareOnReset>false</ReloadFirmwareOnReset>
    <ValidateEndOfStackAddress>true</ValidateEndOfStackAddress>
    <StopAtEntryPoint>false</StopAtEntryPoint>
    <EnableVirtualHalts>false</EnableVirtualHalts>
    <DynamicAnalysisSettings/>
    <EndOfStackSymbol>_estack</EndOfStackSymbol>
    <TimestampProviderTicksPerSecond>0</TimestampProviderTicksPerSecond>
    <KeepConsoleAfterExit>false</KeepConsoleAfterExit>
    <CheckInterfaceDrivers>true</CheckInterfaceDrivers>
    </Debug>
    </VisualGDBProjectSettings2>
    #25163
    Unfortunately, the project file you copied is corrupt (e.g. the CMakeTargetSpecificSettings tag is not closed), so we were not able to reproduce the issue with it.
    We have tried creating a similar project from scratch (ESP-IDF, CMake) and built it using the following command line:
    VisualGDB.exe /build Project.vgdbproj /config:Release
    This did work as expected. Please double-check that you are using the latest VisualGDB version and that the newly created project builds the release configuration as expected.
    Then try comparing your project with the newly created one to see what setting could be interfering with the configuration selection from command line.
    #25168
    sorenml
    Upgrading to newest version made all the difference, thank you 🙂
