VGDB and android
Sysprogs forums › Forums › VisualGDB › VGDB and android
  • #552
    I downloaded trial of VGDB with intention to setup my android build on Visual Studio.
    I installed the extension and imported my android project. I selected not to modify my android.mk (it’s big and complex and conditionally includes many other makefiles).
    The problem is that I cannot do anything else after that since the buildstep is kind of retarded:
    “$(VISUALGDB_DIR)VisualGDB.exe” /build AndroidApp1-Debug.vgdbsettings
    and somehow from this line it calls:
    C:android-ndk-r8bndk-build.cmd NDK_DEBUG=1 APP_PLATFORM=android-14
    But this isn’t going to work with my build since I need to pass many parameters on the make line and search path (for the make.exe itself). Is there a way to specify all these params manually?
    thanks
    #2353
    You can specify additional parameters to make by right-clicking on the project in Solution Explorer, selecting “VisualGDB Project Properties” and specifying additional ndk-build arguments. The ndk-build.cmd is currently fixed and cannot be changed via settings. If you want to use a custom build script instead, please write a letter to support@sysprogs.com, we’ll send you a custom build that can do it.
