Using arm-none-eabi-objcopy.exe
Sysprogs forums Forums VisualGDB Using arm-none-eabi-objcopy.exe
  • #29550
    runout
    I want to generate *.s37-File in this way:
    “%VISUALGDB_DIR%GCCCommandDumper\arm-none-eabi-objcopy.exe” -v -O “foo.axf” “foo.s37”
    Doesn’t work! Abort with message “Please define SYSPROGS_GCC_COMMAND_DUMPER_INSTANCE via environment.”
    What is Env-Variable “SYSPROGS_GCC_COMMAND_DUMPER_INSTANCE” and how to set?
    Any Suggestions?
    kind regards
    Runout
    #29552
    This is not a real objcopy. It’s part of a tool used by VisualGDB to capture the command lines that mbed would pass to gcc, ld and objcopy, in order to reconstruct the code model.
    Please use the objcopy executable from the toolchain directory instead.
