Sysprogs forums › Forums › VisualGDB › Suspected Project Import Problem or Compiler problem
- This topic has 38 replies, 2 voices, and was last updated 7 years, 8 months ago by
Miao Mico.
January 26, 2019 at 11:23 #23581
Miao Mico
ParticipantI think i find the problem .
The STDPeriph Lib’s .h files are not been included .
And i checked the keil project file and the imported MCU.xml .
The VGDB imported correctly .
But Keil can find the .h along the tree included .
You must be logged in to view attached files.January 26, 2019 at 12:13 #23585Miao Mico
ParticipantBut i add the .h files ,it also can’t work .
January 27, 2019 at 06:17 #23590support
In Visual Studio the include search paths need to be specified explicitly. Just adding headers to Solution Explorer will not automatically let your code discover it. Simply add the directories with headers to VisualGDB Project Properties -> MSBuild -> Include Directories and MSBuild will be able to find them.
You can also use the VisualGDB’s header discovery logic – it should normally locate the missing headers automatically and suggest updating the project properties for you. You can read more about this feature here: https://visualgdb.com/tutorials/intellisense/headers/
January 27, 2019 at 06:23 #23591Miao Mico
ParticipantThanks .
I will try .
Come back soon .
February 5, 2019 at 05:51 #23686Miao Mico
Participantbut it can’t work …
beacuse my project has includes the direction ,otherwise the keil project won’t be available .
And you said the VSGDB project imported correctly from the keil project.
February 5, 2019 at 05:54 #23687Miao Mico
Participantthis problem is the biggest one holding back my using the VSGDB .
February 5, 2019 at 06:11 #23688support
Sorry, we are not sure what you meant. The project should normally import correctly as long as the original Keil project has the correct include paths.
Please try locating a specific header that is not being found and ensure that its location is listed in the Include Directories field in VisualGDB Project Properties.
Alternatively please try reproducing the problem on a smaller Keil project (that builds with Keil, but doesn’t build after being imported) and attach it here so that we could investigate.
February 5, 2019 at 06:45 #23689Miao Mico
ParticipantMy question is the VSGDB project imported from the normal keil project can’t compile succeed .
Why ?
the vs show this outputs below:
than i find the Header files -> FWLIB that wish contain the STDPeriph Lib’s .h files is empty .
and i goto the MSbuild find the includes dirction contain it :
includes.h
and i add the files(.h) into it it can’t work …
do i say enough to understand it ?
because i am a rookie …
i am very confused …
don’t know how to explain …
Sorrry , sincerely .
You must be logged in to view attached files.February 5, 2019 at 19:46 #23704support
Unfortunately, it is impossible to narrow down the problem based on the limited description you provided. If you could reproduce the problem on a smaller project and attach it here, we should be able to investigate what is going on.
February 6, 2019 at 05:00 #23712Miao Mico
ParticipantOk , if it work , i will attach to the support .
February 6, 2019 at 13:52 #23719Miao Mico
ParticipantSupport has been updated .
Hopes it will work .
February 6, 2019 at 20:03 #23721support
KeymasterThanks for sending us the repro. Turns out the project included its own modified versions of the system headers and the Keil IDE included them before the regular headers, while VisualGDB included them after.
We have updated VisualGDB to match the Keil behavior in this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.100.2788.msi
Please import the project again.
February 7, 2019 at 04:42 #23741Miao Mico
ParticipantThanks .
Let me try it .
February 7, 2019 at 05:38 #23742Miao Mico
ParticipantAnd …
it still have problem .
Will the c/c++ language standard will be imported ?
Many times , error will catched because this is not same as the keil project .
February 7, 2019 at 07:02 #23744support
KeymasterSorry, the language standard does not get automatically imported for Keil projects, however you can simply change it via the VS project properties.
We have rechecked the project you previously sent us and it does get imported correctly. If you still run into problems, please send us the updated repro project.
