Silicon Labs Gecko SDK Suite under VGDB
Sysprogs forums Forums VisualGDB Silicon Labs Gecko SDK Suite under VGDB
  • #34660
    tim
    is it possible to implement the Silabs Gecko SDK (4.3.1) in VisualGDB?
    VGDB only offers a Toolchain, but no SDK.
    for example the system_efm32*.c and startup_efm32*.c are quit different.
    any suggestions?
    Kind Regards
    Thomas
    #34667
    No problem. Our previous EFM32 package was based on an older Gecko SDK (4.0.2). We have just updated it based on the latest release from Github (4.2.4, 32-bit SDK version 6.4.4).
    If you would like to use the SDK files that are not included in the BSP, you can manually clone the SDK (make sure you are using the same version) and add the files to the project. If you would like to pull some of the libraries from the SDK into the BSP so that they could be added via VisualGDB GUI, you can patch our EFM32 BSP Generator. It currently only wraps the most basic libraries.
    We also updated our EFM32 tutorial showing the new VisualGDB GUI and explaining how to find the SDK version.
