Running Unit Tests from CI
Sysprogs forums Forums VisualGDB Running Unit Tests from CI
  • #36291
    Umair
    Hi community,
    I was recently working on running Unit Tests from CI on a remote target via J-Link network debugger. I successfully configured things on agent server and successfully ran Unit Test from CI.
    But after 2 weeks working successfully, yesterday the CI starts to fail(timeout). It seems like the VisualGDB process just stuck and no unit tests run until that task timeout. Here you can see;
    Thanks in advance
    • This topic was modified 1 year, 5 months ago by Umair.
    #36297
    The screenshots don’t show anything definitive, so you can try just running it manually from the same user account and check the output. But, given the timing, most likely, the 30-day trial period has elapsed and VisualGDB is now asking for the license key.
