Received a SIGTRAP: Trace/breakpoint trap
Sysprogs forums Forums VisualGDB Received a SIGTRAP: Trace/breakpoint trap
  • #21384
    mattia
    I’m using an ESP32 with Segger J-link on VisualGDB 5.4. When I use a breakpoint, I often get the message “Received a SIGTRAP: Trace/breakpoint trap” after I press F10 to see the successive instruction. Is there a way to avoid it?
    Thank you,
    Mattia
    #21403
    This might be an OpenOCD or gdb bug (unfortunately the ESP32 debugging tools are not as mature as the ARM tools). If you could reproduce this on a basic “blink” project and let us know the exact steps to reproduce it on our side, we could check if there is an easy workaround.
