Qt5 Project on Raspberry Pi 5 Bookworm
Sysprogs forums Forums VisualGDB Qt5 Project on Raspberry Pi 5 Bookworm
  • #35571
    nahumb
    I’m trying to create a Qt5 c++ application on a Raspberry Pi 5 running the latest Bookworm OS using the latest toolchain and the VGDB wizard.
    When asked to sync the Sysroot folder, there are a lot of warnings, for example:
    Unreadable remote directory ‘usr/lib/ssl/private’, error code 13
    Failed to create file ‘usr/lib/systemd/system/system-systemd/x2dcryptsetup.slice’: The system cannot find the path specified
    Failed to read file ‘usr/lib/cups/backend/cups-brf’, error code 13
    Failed to read file ‘usr/lib/cups/backend/vnc’, error code 13
    Failed to read file ‘usr/lib/cups/backend/implicitclass’, error code 13
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\include\python3.11\numpy’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\include\clang\14\include’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\include\clang\14.0.6\include’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\include\libcamera-apps’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\aarch64-linux-gnu\icu\current’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\aarch64-linux-gnu\perl\5.36’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\aarch64-linux-gnu\samba\ldb\compat’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\clang\14\include’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\clang\14\lib’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\clang\14.0.6\include’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\clang\14.0.6\lib’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\modules\6.6.20+rpt-rpi-2712\source’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\modules\6.1.0-rpi8-rpi-2712\source’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\modules\6.1.0-rpi7-rpi-2712\source’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\chromium-browser\libs’, error code 1314
    Failed to expand directory symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\chromium-browser\libs’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\firmware\raspberrypi\bootloader-2711\critical’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\firmware\raspberrypi\bootloader-2711\stable’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\firmware\raspberrypi\bootloader-2711\beta’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\firmware\raspberrypi\bootloader-2712\critical’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\firmware\raspberrypi\bootloader-2712\stable’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\usr\lib\firmware\raspberrypi\bootloader-2712\beta’, error code 1314
    Failed to create symlink ‘\\?\C:\SysGCC\raspberry64\gcc12_2_0\arm-linux-gnueabihf\sysroot\lib’, error code 1314
    When continuing, it keeps asking to add missing Qt headers.
    And then I get an error dialog: Test program appears inconsistent.
    Expected return code: 108. Actual return code: 127.
    Run “/home/pi/tests/VisualGDB_ToolchainTestProgram_Deployed T” in directory “” on local computer
    bash: line 1: /home/pi/tests/VisualGDB_ToolchainTestProgram_Deployed: cannot execute: required file not found
    Command exited with code 127
    Can any one assist, pleas.
    Nahum Budin.
    • This topic was modified 2 years, 2 months ago by nahumb.
    #35573
    #35577
    nahumb
    Renewed.
    Nahum.
    #35578
    Thanks for renewing. Please make sure you update to VisualGDB 6.0, then follow the steps below:
    1. Delete the toolchain you have.
    2. Download a toolchain from here that matches your SD card image.
    3. Make sure you can build and debug a basic executable (non Qt-based) using that toolchain. If it doesn’t work, replace your SD card contents with a fresh image per our toolchain list.
    4. Once the basic program works, follow our Qt/CMake tutorial to get everything working.
    #35579
    nahumb
    Did it all.
    A basic CMAKE executable is working fine (“Hello World”).
    Qt-based project build yield the following result:
    Run "C:\PROGRA~2\Sysprogs\VISUAL~1/ninja.exe " in directory "I:\Workspace\RaspberryPi5\VS_VGDB\LinuxProjectQtTeat20240419/build/VisualGDB/Debug" on local computer
    [1/5] Automatic MOC and UIC for target LinuxProjectQtTeat20240419
    [2/5] Building CXX object CMakeFiles/LinuxProjectQtTeat20240419.dir/LinuxProjectQtTeat20240419_autogen/mocs_compilation.cpp.o
    [3/5] Building CXX object CMakeFiles/LinuxProjectQtTeat20240419.dir/MainWindow.cpp.o
    [4/5] Building CXX object CMakeFiles/LinuxProjectQtTeat20240419.dir/LinuxProjectQtTeat20240419.cpp.o
    [5/5] Linking CXX executable LinuxProjectQtTeat20240419
    FAILED: LinuxProjectQtTeat20240419
    cmd.exe /C "cd . && C:\SysGCC\raspberry64\bin\aarch64-linux-gnu-g++.exe --sysroot=C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot -g -rdynamic CMakeFiles/LinuxProjectQtTeat20240419.dir/LinuxProjectQtTeat20240419_autogen/mocs_compilation.cpp.o CMakeFiles/LinuxProjectQtTeat20240419.dir/LinuxProjectQtTeat20240419.cpp.o CMakeFiles/LinuxProjectQtTeat20240419.dir/MainWindow.cpp.o -o LinuxProjectQtTeat20240419 C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Widgets.so.5.15.8 C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8 C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8 && cd ."
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libz.so.1, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libdouble-conversion.so.3, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libicui18n.so.72, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libicuuc.so.72, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libpcre2-16.so.0, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libzstd.so.1, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libglib-2.0.so.0, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libGL.so.1, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libpng16.so.16, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libharfbuzz.so.0, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: warning: libmd4c.so.0, needed by C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8, not found (try using -rpath or -rpath-link)
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_main_context_pop_thread_default'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_main_context_unref'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_funcs_set_nominal_glyph_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_interlace_handling@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_IHDR@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_face_destroy'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_compile_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_io_ptr@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_unicode_funcs_create'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_unicode_funcs_set_general_category_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_image_width@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_blob_get_empty'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_close_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_jit_stack_assign_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_source_remove_poll'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_match_data_create_from_pattern_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_longjmp_fn@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `glLoadIdentity'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `double_conversion::DoubleToStringConverter::DoubleToAscii(double, double_conversion::DoubleToStringConverter::DtoaMode, int, char*, int, bool*, int*, int*)'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_get_glyph_infos'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_gray_to_rgb@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_destroy'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_get_glyph_positions'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_create'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_add_utf16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_getMaxCharSize_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_face_is_immutable'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_bgr@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_getAlias_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_valid@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_countAvailable_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_funcs_set_font_h_extents_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_write_rows@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `UCNV_FROM_U_CALLBACK_SUBSTITUTE_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_set_ppem'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_PLTE@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_face_create_for_tables'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_sig_bytes@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_write_chunk@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_pHYs@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ZSTD_getErrorName'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_match_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_set_segment_properties'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `compress2'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucol_open_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_swap@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_unicode_funcs_set_decompose_compatibility_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_destroy_read_struct@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucol_close_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_x_pixels_per_meter@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_source_new'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_read_row@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_clear_contents'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_reverse'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_get_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_option@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_set_flags'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_sRGB@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_main_context_pending'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_tRNS@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_pre_allocate'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_allocation_successful'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `double_conversion::StringToDoubleConverter::StringToDouble(char const*, int, int*) const'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_set_user_data'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_error_fn@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucol_strcoll_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_countAliases_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_match_context_create_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_destroy'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_close_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ZSTD_decompress'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_shape_full'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_source_add_poll'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_set_unicode_funcs'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_get_user_data'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_getDefaultName_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_packing@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_fromUnicode_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `deflate'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_config_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_read_end@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_read_fn@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_main_context_push_thread_default'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `deflateEnd'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_write_end@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `compress'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_funcs_set_glyph_extents_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_invert_mono@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_main_context_ref'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ZSTD_getFrameContentSize'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_getAvailableName_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_write_fn@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_tRNS@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_create_write_struct@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_source_attach'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_getDSTSavings_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_error@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_destroy_write_struct@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_jit_stack_free_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_packswap@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_funcs_set_glyph_h_kerning_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_text@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_strip_16@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_clone_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_source_destroy'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `crc32'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `glMatrixMode'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_jit_stack_create_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_create_read_struct@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_source_set_can_recurse'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_benign_errors@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_unicode_funcs_set_mirroring_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_blob_create'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_compareNames_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_set_ptem'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_oFFs@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_getDefaultTimeZone_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_main_context_new'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucol_setAttribute_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `inflateInit2_'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_setFromUCallBack_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_openTimeZoneIDEnumeration_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_PLTE@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_funcs_set_glyph_h_advance_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `glOrtho'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_unicode_funcs_set_eastasian_width_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_compression_level@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_match_context_free_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_is_immutable'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_source_unref'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_unicode_funcs_destroy'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_text@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_filler@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_gAMA@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_pattern_info_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_face_set_index'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_openTimeZones_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_funcs_set_glyph_contour_point_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_unicode_funcs_set_decompose_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_open_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_main_context_default'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_funcs_create'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ZSTD_isError'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `inflate'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_IHDR@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `u_strToLower_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `u_strToUpper_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_set_funcs'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_jit_compile_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_unicode_funcs_set_combining_class_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_guess_segment_properties'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_main_context_iteration'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_expand@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_cHRM@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_set_scale'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `md_parse'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `deflateInit2_'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_face_set_upem'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_write_info@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_code_free_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_ot_tags_from_script'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `deflateInit_'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_funcs_set_variation_glyph_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_get_ovector_pointer_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_ot_layout_table_find_script'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_open_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_funcs_destroy'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_unicode_funcs_set_compose_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_get_error_message_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `g_main_context_wakeup'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_oFFs@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_create_info_struct@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_openCountryTimeZones_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_get_length'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_iCCP@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `uncompress'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_read_update_info@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_setSubstChars_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucol_getSortKey_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_write_image@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_gamma@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_getTimeZoneDisplayName_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_font_funcs_make_immutable'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_y_pixels_per_meter@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `uenum_close_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_image_height@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_inDaylightTime_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_read_image@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `u_errorName_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_read_info@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_getStandardName_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_unicode_funcs_set_script_func'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `pcre2_match_data_free_16'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `hb_buffer_create'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_set_gAMA@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucnv_toUnicode_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `uenum_next_72'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `inflateEnd'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_channels@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `glLoadMatrixf'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.15.8: undefined reference to `png_get_iCCP@PNG16_0'
    c:/sysgcc/raspberry64/bin/../lib/gcc/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld.exe: C:/SysGCC/raspberry64/aarch64-linux-gnu/sysroot/usr/lib/aarch64-linux-gnu/libQt5Core.so.5.15.8: undefined reference to `ucal_setMillis_72'
    ninja: build stopped: subcommand failed.
    Executable: C:\PROGRA~2\Sysprogs\VISUAL~1/ninja.exe
    Arguments:
    Directory: I:\Workspace\RaspberryPi5\VS_VGDB\LinuxProjectQtTeat20240419/build/VisualGDB/Debug
    Environment: LANG=en_US.UTF-8|PATH=C:\SysGCC\raspberry64\bin;C:\SysGCC\raspberry64\bin;%PATH%|TOOLCHAIN_ROOT=C:/SysGCC/raspberry64|EFP_BASE=C:/Users/Nahum/AppData/Local/VisualGDB/EmbeddedEFPs|TESTFW_BASE=C:/Users/Nahum/AppData/Local/VisualGDB/TestFrameworks|TESTFW_BASE_LOCAL=C:/Users/Nahum/AppData/Local/VisualGDB/TestFrameworks
    Command-line action failed
    ========== Project Build Summary ==========
    LinuxProjectQtTeat20240419 built in 00:04
    ========== Build: 0 Succeeded, 1 Failed, 0 Skipped ==========
    #35580
    Thanks, the “undefined reference” error is actually a glitch in the new 64-bit Raspberry Pi toolchain.
    Please try creating the <SysGCC>\raspberry64\aarch64-linux-gnu\sysroot\etc\ld.so.conf file with the following contents:
    /opt/vc/lib
    # Multiarch support
    /usr/lib/aarch64-linux-gnu/libfakeroot
    # libc default configuration
    /usr/local/lib
    We have also updated the toolchain on our side to include this file out-of-the-box.
    • This reply was modified 2 years, 2 months ago by support. Reason: updated path
    #35584
    nahumb
    OK.
    Now it works.
    Thanks for your support and fixing the glitch.
    Nahum.
