Sysprogs forums › Forums › VisualGDB › Problem Error building after update to new release
- This topic has 23 replies, 2 voices, and was last updated 7 years ago by
SHA.
July 19, 2019 at 12:18 #25402
SHA
ParticipantHi Dears,
I have problem with my visual GDB & embedded beaglebone toolchain , after update to last release, i can’t build my project give me many strange errors .
What shall I do to get back all configurations?
This topic was modified 7 years, 1 month ago by
SHA.
July 19, 2019 at 19:43 #25407support
Most likely the problem is caused by some configuration change on your side and is not related to the update.
Please try narrowing down the problem to a specific sequence of steps that doesn’t work (see the 3-step reporting guidelines here) and we should be able to help you get it to work.
July 25, 2019 at 08:38 #25447SHA
I’m trying to build project for embedded Linux with QT, the project work fine with old setting after dam update it’s can’t be build, and I supposed to deliver the project next month !!
I Get this Error below:
Error Cannot run compiler ‘g++’Error Command-line action failed
Error MSB3073 The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “D:\local\x\x1\y\y1\y12.vcxproj” “/solution:D:\local\x\x1\y\y12.sln” “/config:Debug” “/platform:Win32″” exited with code 1. y1 C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets 41-
This reply was modified 7 years, 1 month ago by
SHA.
July 25, 2019 at 09:27 #25449SHA
ParticipantNote: if I create new project it’s work fine
but my old projects failed đ
July 25, 2019 at 15:49 #25453support
KeymasterMost likely, the problem is triggered by an accidental change of some settings of the project or a toolchain. Please try comparing the settings of the working and non-working projects (either compare each page of VisualGDB Project Properties, or compare the .vgdbsettings and .pro files using KDiff or another diffing tool) and then try editing the broken project to match the settings of the working project. If you can narrow down a specific setting, we can check whether it could be caused by a VisualGDB update and release a hotfix, however it is not possible for us to confirm it without knowing a specific setting.
July 26, 2019 at 07:34 #25464SHA
I already do that, compare all files, setting, configuration, uninstall and reinstall … nothing change
All the old projects didn’t compile !
I found only the makefile for the old projects suddenly changed to one line instead of several lines , and some projects changed from Qmake to MSbuild !!
Is that normal ?
Now I’m in serious problem because the software not ready and supposed to be close to delivery !
If possible to tell me what is the required setting to fix that ?
Regards
July 26, 2019 at 13:27 #25472SHA
ParticipantThe same problem with me , after update the Visual GDB and the toolchain by default , now nothing work !!!!!
July 26, 2019 at 13:34 #25475SHA
ParticipantNow … the New update ..
I remove the visual GDB & all toolchians , then reinstall all
i can’t even run new projects with QT cross compile for embedded Linux !
Can someone solve this situation, I hope to found some fast useful respond !!
July 26, 2019 at 14:09 #25476SHA
Participantlibgobject-2.0.so.0 : error : undefined reference to `g_date_copy’
July 26, 2019 at 17:53 #25488support
It looks like you have changed some global setting (e.g. installed an incompatible toolchain, replaced some files in the sysroot, or edited some global file) and that is triggering problems. The best way to troubleshoot this would be to install the toolchain (and flash the SD card image) from scratch, create a new project and ensure that it works, and then either compare the new project’s settings with the old one, or simply move your old project’s files to the new one one by one. There is no easy way to just get everything to build without either knowing what exactly has changed, or re-creating a working setup from scratch.
Specifically, the libgobject-2.0.so error looks like your toolchain is either missing some files, or has been partially overwritten with incompatible versions of some files. Reinstalling the toolchain from scratch as suggested before should solve the problem.
July 29, 2019 at 07:53 #25505SHA
Participanthi dears,
still the same problem.
even after reinstall everything !!
the old projects totally not able to compile !
the new project work with basic lib.
as example , if i added serialport lib to the .pro file give me this statement in the debug
Project MESSAGE : warning : unknown QT: serialport
SHA.
July 29, 2019 at 07:56 #25507SHA
ParticipantThe second issue !
I install the new release of visualGDB then reinstall all available toolchains for raspberry pi and beaglebone platforms! also give me same errors
Should i try older release of VisualGdb!?
SHA.
July 29, 2019 at 08:54 #25509SHA
Participantanother note:
when i try to update the sysroot give me this error in log
Failed to create symlink < with several files in the target hardware , but the files exist ! >
July 29, 2019 at 15:57 #25511support
Each VisualGDB release it tested via ~100 integration tests that verify creating, building, debugging and editing of different project types, hence the problem is likely not caused by a recent VisualGDB update, but is triggered by accidental changes to some global settings (e.g. switching to an incompatible toolchain).
The “unknown QT: serialport” message means that Qt is likely missing the serial port library. You might need to install the library via the Linux package manager and then re-synchronize the sysroot.
If some projects build with the serialport library, while others don’t, the only way to get the old projects to work is to compare the working projects with non-working ones and eliminate the differences.
Unfortunately, as you have not provided any details on the other error messages you got, it is hard to suggest anything specific. If you could attach a screenshot, or the full text of the error, we can help you understand what it means.
July 30, 2019 at 08:09 #25516SHA
I install New Linux
install new visual GDB
install new toolchain as below:
1. let the visual GDB suggest the suitable toolchain during create the project !
2. i chose the toolchain by my self !
In all above, failed to compile hello world QT cross compile !
If I chose to build the project remotely on the target , it’s Work Fine !
But, if I chose to build it on my windows machine , give my cocktail of Errors !
During these days ! i notice you published several releases of visual GDB, please if you have problem ! Inform me
Because now I’m in serious problem ! I’m working on big project since several months and have no problems ! And when I asked you if the update could change the setting ! And you confirm no ! But unfortunately it’s does.
What should I do now ? Time remaining for me less than month !?
Next: i will post a sample of errors i got
SHA.
