Debug multiple projects in a solution at the same time
Sysprogs forums › Forums › VisualGDB › Debug multiple projects in a solution at the same time
  • #36832
    Juergen
    Hello, I recently purchased VisualGDB and am currently trying to debug multiple projects in a solution at the same time. How can I do this? Visual Studio itself offers this feature, as you can see in the screenshot.
    Background: I want to write an SPI master-slave application with a shared library, but when I do that, I can only debug one application at a time and not both at the same time. Is the only option to use them in two different solutions, but then I can’t use a shared library?
    #36840
    Sorry, due to several complications in the way VS handles debugger interfaces, VisualGDB only supports debugging one application at the same time.
    If you would like to debug 2 applications simultaneously, you would need to run 2 separate Visual Studio instances having 2 different solutions.
    That said, two solutions can easily reference the same static library (embedded targets do not support shared, i.e. dynamically loaded libraries anyway).
