Precompile settings
Sysprogs forums › Forums › VisualGDB › Precompile settings
  • #839
    darksilence
    Suddenly I’ve lost precompile seetings for my project.
    It’s very important and now it doeasn’t work. Where can I find it (ver.4.2 Beta 1/2)
    Now in VisualGSB project properties I dont have all the settings that I had only 3 days ago 🙁
    #3208
    Please refer to the following topic regarding precompiled header support: viewtopic.php?f=5&t=2769
    #3206
    darksilence
    I’m sorry for confuse, but I wanted to understand what happened with Prebuild options. In release VisualGDB I still can use it, but in Beta1/2 I can’t find it.
    P.S. this option runs script or Application before build
    #3207
    Do you mean the pre-build steps in VisualGDB Project Properties? They are only available in Custom and Ultimate editions. If you were using a trial before and then bought a lower edition, the options would go away after the trial expires.
    #3209
    darksilence
    O_o I didn’t even see those features… uhm..
    Ok… I found how to make post-biuld scripts in a make-file. But I didn’t figure out how to make pre-build step….
    #3210
    The easiest way to have a pre-build action without using the custom edition features would be to change the make command to run a bat file that first runs your custom command line and then invokes GNU make. It is not as convenient as the pre-build action list, but may work for some basic scenarios.
    #3204
    darksilence
    just in case
    VisualGDB Project Properties: Makefile settings: Make command: “cmd.exe /c “Build.cmd” “
    build.cmd:
    @echo off
    REM Here you can Add prebuild options
    REM Here you can change the toolchain
    C:SysGCCarm-eabibinmake.exe  %*
    #3205
    Yes, that should work.
