Large Heap Size Breaks Live Watch (FreeRTOS)
Sysprogs forums Forums VisualGDB Large Heap Size Breaks Live Watch (FreeRTOS)
  • #35340
    bflannery
    I have 16MB of external SDRAM I use for my heap. When I expand the “Heap” section in the “FreeRTOS” tab of the “Live Watch” window it breaks live watch completely and no longer updates.
    #35341
    The heap view in Live Watch is indeed designed for much smaller heaps that would typically fit into the on-chip SRAM and can be polled at a reasonable rate. Reading out 16MB of SDRAM over a typical JTAG connection would indeed take several minutes, and would not be really practical.
    #35344
    bflannery
    Understood. I figured that would be the case. I just thought I would let you know that the way it fails is not a good experience and impacts the other aspects of debugging. I will avoid expanding that section myself moving forward, but I imagine I won’t be the last person to run into this.
    #35346
    No problem. We will monitor the feedback from other users and will consider adding a warning if others encounter the same issue.
