How/where to provide command line parameter of app do debug?
Sysprogs forums Forums VisualGDB How/where to provide command line parameter of app do debug?
  • #10099
    hfrmobile
    Where can a specify command line parameters to the app I like to debug?
    Standard VS project setting will be ignored.
    myapp -p1 -p2
    #10105
    You can do it via VisualGDB Project Properties -> Debug Settings -> Program Arguments.
    #10116
    hfrmobile
    To be more accurate: VisualGDB Project Properties -> Debug Settings
    Start GDB in the following mode: Debug a new instance
    Debugged executable: $(TargetPath)
    Main executable arguments: -p1 -p2
    The cause why I asked was that didn’t find because it really was not visible because my “Start GDB in the following Mode” was set to custom. In that case, no arguments can be provided.
    Anyway, problem solved.
