How to use source file from samba shared file directly during debug
Sysprogs forums › Forums › VisualGDB › How to use source file from samba shared file directly during debug
  • #13265
    fotwo
    I built, actually, imported a project from Linux(Centos) via Samba and SSH. I have already been able to debug the binary from Windows through Visual Studio. I find the corresponding source files are all from temporary directory, such as “C:****\VisualGDB\AutoDownloadedSources\****”, which are opened slowly sometimes. The more serious issue is that I can not do something, for example, right click one class type and “go to definition”. After that, I find if I use VA(visual assist) to “Find References”, which is conducted in Samba shared files, then I can “go to definition” and open related source file quickly.
    I think if I use the samba shared files directly as the debugging source file, I can get the same results. Therefore, how to use source file from samba shared file directly during debug? Thanks.
    #13272
    VisualGDB would put the sources into AutoDownloadedSources if it doesn’t know how the Windows path corresponding to them. Could you please give an example of a file (i.e. full path) that gets opened via this mechanism and let us know your shared folder settings (a screenshot or a summary of used paths)?
    Regarding “Go to Definition”. Please try locating the source file that should normally contain the definition of the symbol and check that:
    • It is included in one of the open projects in Solution Explorer
    • Physically present on the disk and accessible via VS
    • Does not show any critical errors when opened from VS
    Please also try enabling the Clang IntelliSense engine – it uses a different mechanism for locating definitions and should work better with remote projects.
