How to select the Toolchain for your target
Sysprogs forums › Forums › VisualGDB › How to select the Toolchain for your target
  • #25466
    SHA
    Hi Dears,
    based on this tutorial →  https://gnutoolchains.com/beaglebone/
    How can I know what is the suitable toolchain for my target ?
    Best Regards
    #25481
    The page you mentioned lists compatible SD card images for each toolchain. If you are not sure which image you are using, we advise starting with a clean toolchain and a clean image compatible with it in order to avoid strange errors.
    If you want to use a different SD card image, please contact the image vendor for a compatible toolchain instead.
