ESP32 Error Cahnging ESP/IDF Checkout
Sysprogs forums › Forums › VisualGDB › ESP32 Error Cahnging ESP/IDF Checkout
  • #31986
    ZeroWorks
    This morning I received an toolchain update for ESP32 (8.4.0/8.1.0/r7). Once applied the ESP/IDF checkout has stop working. I deleted esp folder and Visual GDB downloaded all again: toolchain and ESP/IDF but it didn’t worked.
    If I go to project properties and try to manually select an ESP/IDF checkout an error it’s raised:
    VisualGDB version: 5.6.102.4506
    —————— System.InvalidOperationException ——————
    System.InvalidOperationException: Error en el documento XML (8, 5). —> System.Xml.XmlException: La etiqueta de apertura ‘IDFCheckoutDatabase’ en la línea 2 posición 2 no coincide con la etiqueta de cierre de ‘Checkouts’. línea 8, posición 5.
    en System.Xml.XmlTextReaderImpl.Throw(Exception e)
    en System.Xml.XmlTextReaderImpl.ThrowTagMismatch(NodeData startTag)
    en System.Xml.XmlTextReaderImpl.ParseEndElement()
    en System.Xml.XmlTextReaderImpl.ParseElementContent()
    en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderIDFCheckoutDatabase.Read4_IDFCheckoutDatabase(Boolean isNullable, Boolean checkType)
    en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderIDFCheckoutDatabase.Read5_IDFCheckoutDatabase()
    — Fin del seguimiento de la pila de la excepción interna —
    en System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
    en System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream)
    en BSPEngine.XmlTools.LoadObject[_Ty](String xmlFile, Type[] extraTypes)
    en VisualGDB.WPF.Embedded.IDFCheckoutSelector.ControllerImpl.AddNewCheckout(IDFCheckout newCheckout)
    en VisualGDB.WPF.Embedded.IDFCheckoutSelector.ControllerImpl.LocateCheckout()
    trace=[System.Xml.Serialization.XmlSerializer.Deserialize:284, System.Xml.Serialization.XmlSerializer.Deserialize:21, BSPEngine.XmlTools.LoadObject:49, VisualGDB.WPF.Embedded.IDFCheckoutSelector+ControllerImpl.AddNewCheckout:33, VisualGDB.WPF.Embedded.IDFCheckoutSelector+ControllerImpl.LocateCheckout:308]
    —————— Inner exception ——————
    —————— System.Xml.XmlException ——————
    trace=[System.Xml.XmlTextReaderImpl.Throw:39, System.Xml.XmlTextReaderImpl.ThrowTagMismatch:158, System.Xml.XmlTextReaderImpl.ParseEndElement:0, System.Xml.XmlTextReaderImpl.ParseElementContent:329, Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderIDFCheckoutDatabase.Read4_IDFCheckoutDatabase:694, Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderIDFCheckoutDatabase.Read5_IDFCheckoutDatabase:80]
    I tried to revert to previous version but unfortunaelly it didn’t work.
    Also I’ve reinstalled VisualGDB.
    So I guess there’s a problem with a XML file.
    Could you help me please?
    #31987
    ZeroWorks
    I’ve found the problem…In  …\sysGCC\esp32 folder the file IDFCheckouts.xml is invalid:
    <?xml version=”1.0″?>
    <IDFCheckoutDatabase xmlns:xsi=”http://www.w3.org/2001/XMLSchema-instance&#8221; xmlns:xsd=”http://www.w3.org/2001/XMLSchema”&gt;
    <IDFCheckout>
    <Version>v4.3.2</Version>
    <Subdirectory>esp-idf/v4.3.2</Subdirectory>
    <Type>ESPIDF</Type>
    </IDFCheckout>
    </Checkouts>
    </IDFCheckoutDatabase>
    Checkouts is not opened but closed… I’ve added <Checkouts> and then I can manually select ESP/IDF version. Maybe there’s a problem with XML Writer.
    Thank you!
    #31988
    Sorry about that, this indeed looks like the earlier version of the toolchain got cached incorrectly. Adding the missing <Checkouts> tag will indeed fully solve the problem. We have also updated the cache on our side, so that other users will get the correct toolchain with the valid XML file.
