Sysprogs forums › Forums › VisualGDB › CC3220 BSP Updates
- This topic has 13 replies, 3 voices, and was last updated 3 years, 11 months ago by
flynnjs.
February 3, 2018 at 22:28 #19931
hoterpone
ParticipantThe VisualGDB support for the TI CC3220 MCU references TI’s SimpleLink v1.40.01 from about the middle of 2017. TI has since released two subsequent versions (now 1.60.00.04), I was wondering if you have any plans to update your BSP to the current version?
AJ
February 4, 2018 at 01:59 #19935support
No problem, we have updated our BSP to the latest SDK. You can install the new package via Tools->VisualGDB->Manage VisualGDB Packages.
February 6, 2018 at 15:51 #19971hoterpone
ParticipantThanks very much!
AJ
July 7, 2020 at 09:18 #28691hoterpone
ParticipantTI’s SimpleLink SDK has gone through several more revisions — they are now at v4.10.00.07. Do you have plans to update your BSP to the current version?
I’m not sure if it’s related to the out-of-date BSP, but I just tried updating the ARM toolchain and OpenOCD to your latest and I can no longer debug my CC3220 device. Just prior to updating this morning I had confirmed that everything worked. I took a screenshot prior to the update that shows my original and updated versions (attached as VisualGDB Packages.png).
AJ
You must be logged in to view attached files.July 7, 2020 at 10:38 #28696support
The CC3220 devices have a considerably smaller user based compared to mainstream device families, such as STM32, hence we indeed don’t update the CC3220 BSP as often.
We should be able to update our CC3220 BSP based on the latest SDK from TI (and also help you resolve any OpenOCD issues you get), however we would kindly ask you to renew your license first.
July 7, 2020 at 15:02 #28697hoterpone
ParticipantYes of course, sorry – I didn’t realize our support had expired 2 weeks ago. I have renewed our license.
AJ
July 8, 2020 at 09:36 #28712support
KeymasterThanks for renewing your license.
We have updated our CC3220 BSP based on the latest SDK from TI (v4.20.00.07). You can install it via Tools->VisualGDB->Manage VisualGDB Packages. Please also ensure you use the latest VisualGDB 5.5 Preview 7.
We have retested it with CC3220 Launchpad using the latest OpenOCD (0.10.0 2020-07-01) and it did work as expected, aside from the “most device registers are zero” error that can be safely ignored for CC3220. If it doesn’t work on your side, please share a screenshot of the error you get and we will help you resolve it.
July 21, 2020 at 03:40 #28763flynnjs
ParticipantI have updated and I can confirm the network terminal example works on the CC3235 and verfied wifi working on channel 36.
I now have a sensible environment to do embedded 5GHz wifi development which is very welcome!
I too have renewed license, well worth it. As always, one step ahead of the competition, many thanks.
July 29, 2020 at 13:58 #28812hoterpone
ParticipantI agree, this update appears to be working fine on my CC3220SFMOD. I have seen a couple of build issues, but I suspect they are due to the VisualGDB update and not the BSP update. In any case, I have reported these under a separate ticket at https://sysprogs.com/w/forums/topic/build-errors-after-upgrading-to-visualgdb-5-5-preview-7/.
AJ
June 14, 2021 at 07:47 #30690flynnjs
ParticipantAny chance to update this to v5.10 as it brings a number of security enhancements (including WPA3) which we need to harden our product with?
Jason
June 15, 2021 at 12:32 #30702support
We are planning to look into CC3220 update in the next 4-5 weeks. We will post an update here once we have a new BSP available.
September 22, 2021 at 08:07 #31354hoterpone
ParticipantDo you have any news/schedule on the CC3220 update?
AJ
September 24, 2021 at 15:49 #31372support
Sorry it took longer than expected with the CC3220 update, as the amount of changes to the SDK was a bit more than we anticipated. We have just released an updated BSP based on the latest SDK 5.20. You can install it conveniently via VisualGDB Package Manager.
April 23, 2022 at 07:32 #32551flynnjs
ParticipantBit late to chime in, but thanks for doing this, really helps!
