I’m having problems getting a command line commands to run after the build of a project is completed.
I’ve attached a screenshot of the Custom build steps window.
The command
Run "rmdir /Q /S obj_files 2> null" in directory "$(BuildDir)..\bin\" on build machine
is failing with
VisualGDB: Run "rmdir /Q /S obj_files 2>null" in directory "C:\Projects\MyProject\Bootloader..\bin\" on local computer
1> VisualGDB: Error: Failed to start process (C:\Program Files (x86)\Sysprogs\VisualGDB\vgagent.exe /b rmdir /Q /S obj_files 2>null): The directory name is invalid
1> VisualGDB: Error: Build has failed. See the Output window for more details.
1> C:\Program Files (x86)\Sysprogs\VisualGDB\MSBuild\Targets\external.targets(12,3): error : Build failed. Please examine the build output (View->Output) for details.
I tried hard coding the path to cmd.exe into the “Command” line, but that didn’t help.
Why is the command trying to start vgagent.exe and how can I run a windows command line command after a project builds?
You must be
