Sysprogs forums › Forums › WinCDEmu › Call for feature requests
- This topic has 50 replies, 12 voices, and was last updated 12 years, 10 months ago by
Anonymous.
October 28, 2011 at 09:48 #1673
ParticipantAfter uninstalling driver, I restarted the portable version.
A “Driver Installation failed” message tells me: The specified service has been marked for deletion.
Probably one has to reboot… but this is NOT the intension of a ‘portable installation’
stating “You can uninstall the driver at any moment…”
Any way to solve/fix this?(by the way can a regular user (not an administrator) install the portable version?)
October 28, 2011 at 13:49 #1674Anonymous
Write in cmd:
driverqueryNow can install/uninstall again. The software need admin right.
Hope for a new portable version soon…
October 28, 2011 at 20:58 #1675Anonymous
ParticipantThanks for the reply, the driverquery works [this solution should be integrated in the next portable version].
I hoped that the portable version would declare/integrate itself as an USB drive: and there is no need for administrator rights…
If the new portable version would also have a command line functionality this would be a magnificent solution!@x_M wrote:
Write in cmd:
October 29, 2011 at 08:00 #1676Anonymous
If the new portable version would also have a command line functionality this would be a magnificent solution!I don’t think we see soon a new portable version, Bazis not interested at the moment.
Fro the command line, i have suggested a couple of pages ago.November 9, 2011 at 10:53 #1671sancher
ParticipantI’ve registered only to say: Thank you for your Great App!
It’s one of my favourite apps.
I use a portable version.
I’m waiting for a PortableWinCDEmu-3.6.exeNovember 16, 2011 at 14:43 #1677Anonymous
ParticipantWhen the new portable version exit?????????????
We need this feature:
A command-line to mount image
Driverquery to uninstall
DO NOT remove drive before removed the ISOThanks
November 22, 2011 at 07:51 #1678Anonymous
I totally agree.
January 19, 2012 at 13:46 #1686glenstewart
ParticipantI have a use case where the creator of an ISO file needs to make a few small changes to an 8GB ISO file comprised of many thousands of files. It would be SO nice to be able to edit the ISO collection itself, rather than recreate the ISO from scratch.
Likewise, I have a similar use case (less important) where users of the ISO need to adjust a few scripts in the ISO file – otherwise they need to extract it to HD and consume 8GB more disk space for their modified working copy. Again in this case, the ISO should be edited and re-saved for this one-time customization per user.
As the subject line says, these use cases are probably what the creator of the Macintosh DMG format had in mind – it has a mode where a DMG can be Read/Write. If this request can’t be honored using ISO format, and the DMG format is open, I’d like WinCDEmu to handle mounting and authoring DMG files, with the R/W option.
Final note: the image mounting as R/W needs to be command-line enabled too. Once the ISO/DMG is mounted, my use case needs batch scripts to be able to modify the files.
Thanks!
January 19, 2012 at 13:48 #1687glenstewart
ParticipantCan WinCDEmu use mount points instead of requiring drive letters, as described here: http://www.techrepublic.com/blog/datace … etters/383
I have a use case where drive letters are already in short supply due to use in a lot of shared folder needs, and I want to mount several ISO files into a folder hierarchy on an existing drive, much as the link above indicates.
Thanks!
February 3, 2012 at 12:34 #1681Anonymous
Participant@bazis wrote:
Hi, All.
So, which features do YOU want to see in the next version of WinCDEmu?
Planned so far:1. Option to remember mounted drivers after restart
2. Batchmnt should have a flag to use portable driver
3. Unattended uninstallAny other suggestions?
May 12, 2012 at 21:55 #1680Anonymous
ParticipantI just realized my request for zip/7z/rar support was kind of stupid. 😀 I wanted to say thanks for this fantastic program, Bazis! I think the only way you could make this program better is if you update the portable version and synchronize it with the installable version, then maybe add support for ISZ and MDX (compressed MDS/MDF images)(not a big want, but the community may want it). I have started a project on SourceForge called Any2ISO, because I wanted to create a free, open-source alternative to AnyToISO, but if you would like, as I develop that program, you can integrate the disc image converter code into WinCDEmu. So when you right-click on an image that isn’t an ISO, it will have an option to convert it to an ISO. It’s up to you, though. My program will probably end up with it’s own GUI, but until I flesh out a prototype, I don’t know. Lemme know what you think. 😉
July 18, 2012 at 16:54 #1684dupko
INDEEED ❗
September 18, 2012 at 07:14 #1689Anonymous
ParticipantBluray support.
It may have been added, I can’t check at this moment in time.October 12, 2012 at 18:24 #1688Anonymous
INDEEED ❗
Totally agree!
November 2, 2012 at 00:07 #1682Borodin
ParticipantWinCDEmu is a superb piece of software. Both the user interface and the functionality are second to none, including paid-for products, and it seems ungracious to ask for more. However I would like a few things:
- To be notified of the chosen drive letter when an image is mounted
- To be able to predetermine a set of drive letters available for WinCDEmu’s use
- When offering a selection of available drive letters for a mount, to include those already in use by WinCDEmu (including the disk label). Selecting a letter already in use would first force a dismount
