Build errors after upgrading to VisualGDB 5.5 Preview 7
Sysprogs forums Forums VisualGDB Build errors after upgrading to VisualGDB 5.5 Preview 7
Viewing 6 posts - 16 through 21 (of 21 total)
  • #28969
    devrope
    Sorry, the issue is still there in build 3779.
    It worked fine in build 3769.
    #28971
    Strange, could you please double-check the Tools->Options->VisualGDB->Advanced Build->Show build output from VisualGDB projects setting?
    Is it still set to “Regular VS Build Output Window”? Does setting Tools->Options->VisualGDB->General->GUI->Build Results Window Stickiness to 0 solve it?
    #28985
    devrope
    The setting is still “Regular VS Build Output Window”.
    Setting stickiness to 0 doesn’t help either.
    • This reply was modified 5 years, 7 months ago by devrope.
    #28996
    OK, thanks for confirming this. We have updated the output window activation logic to prevent it from gaining focus unless it directly receives output. Please try this build: <old link>
    Update: we have tweaked the logic a bit more to handle skipped projects better. Here is the updated build: VisualGDB-5.5.8.3784.msi
    • This reply was modified 5 years, 7 months ago by support. Reason: new build
    #29003
    devrope
    Thanks, build 3784 solved it!
    #29130
    hoterpone
    I had clicked the link for build 3784’s installer a few days ago to try to resolve the output window issue mentioned above, and in the last 2 days I’ve experienced another 2 instances where the build seems to get stuck (presumably because msbuild isn’t invoking the logic responsible for updating VisualGDB’s floating license state?).  Then I realized that I’m actually running build 3827 now, and the links above don’t seem to work any more when I try to re-download.  Is there an installer that I can get that you expect has both fixes?
    AJ
