Bug? Cannot import SVD file on 5.5.2.3410
Sysprogs forums Forums VisualGDB Bug? Cannot import SVD file on 5.5.2.3410
  • #27096
    curtis.hendrix
    I think I found a bug in VisualGDB version 5.5.2.3410.  I cannot import hardware registers from a .SVD file (attached).
    I ran my firmware and stopped at a break point, then opened the Hardware Registers window.  I clicked on “Import registers from an SVD file or a VisualGDB register definition file” link and opened PAC55XX.svd, and got the following exception:
    VisualGDB version: 5.5.2.3410
    ------------------ System.InvalidOperationException ------------------
    System.InvalidOperationException: Nullable object must have a value.
    at System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource)
    at q11.a(XmlElement c, List<code>1 e, String d, UInt32 b, Nullable</code>1 a)
    at q11.g(String b, String a)
    at o81.j1(Boolean a)
    trace=[System.ThrowHelperThrowInvalidOperationException:16, q11a:87, q11g:295, o81j1:187]
    Edit: Apparently the file is too big.  I removed some peripherals from it and re-uploaded.
    #27098
    curtis.hendrix
    …And apparently .svd files are not allowed.  Okay, let’s try attaching it as a text file.
    #27110
    The error you mentioned happens because the imported SVD file does not define sizes for some registers. We have updated VisualGDB to assume 32-bit registers when the size is not specified: VisualGDB-5.5.2.3446.msi
    That said, the file you attached to the second message appears broken (it triggered an error about mismatching <peripherals> tag), so it will not get imported despite the fix.
    #27116
    curtis.hendrix
    I cut off the end of the file because it was too large.   Try this one.  I removed a few register definitions to get the file under the size limit, but it still exhibits the same problem.
    #27119
    No problem, please try this build: VisualGDB-5.5.2.3447.msi
