Any way to permanently disable the "Download Newlib Source" popup?
Sysprogs forums Forums VisualGDB Any way to permanently disable the "Download Newlib Source" popup?
  • #8889
    CurtisHx
    Is there any way to permanently disable the “You have stepped into the source code of Newlib that was pre-compiled with your toolchain.  VisualGDB can download the source code used to build it (Newlib) and use it for debugging.  Proceed with downloading?” popup?  I keep clicking “NO”, but that pop up keeps coming back, and it’s really, really annoying.
    #8894
    Yes, you can disable this, although it will require some minor XML editing. Please try removing the ‘DownloadableSourcePackage’ elements from the toolchain.xml file in your toolchain directory.
