Advanced Clang IntelliSense. Incorrect tooltip
Sysprogs forums › Forums › VisualGDB › Advanced Clang IntelliSense. Incorrect tooltip
  • #27861
    viordash
    How remove this yellow bar with lamp and button Refresh for remote source cached files.
    The text on bar is like ““The current file is not built by any known projects …”
    #27872
    Please use the “Warn About Detached Files” option. You can find the full path to the option here: https://visualgdb.com/settings/
    Also, feel free to try this build: VisualGDB-5.5.5.3573.msi. It will suggest automatically adding a path mapping rule for automatically downloaded remote files.
    #27875
    viordash
    Thanks. Your solution helped with my problem.
    And the update seems good
