Add option to select ProfilerDriver in stand-alone project
Sysprogs forums › Forums › VisualGDB › Add option to select ProfilerDriver in stand-alone project
  • #11585
    borbmizzet
    Please add an option to select which, if any, ProfilerDriver_*.cpp file to use in the Fast Semihosting and Embedded Profiler options under “VisualGDB Project Properties -> Embedded Frameworks” in a stand-alone embedded project. Adding it manually doesn’t quite work as well when you have to share the project between multiple users, unless you add it to the project folder, in which case you would still have to update it every time SysProgs releases a profiler update.
    #11587
    This should be already fixed in VisualGDB 5.3 Preview 1. Please try updating to it.
