Sysprogs forums › Forums › VisualGDB › Yocto-Linux
- This topic has 42 replies, 2 voices, and was last updated 10 years, 3 months ago by
May 11, 2016 at 14:51 #8207
peter_cz
ParticipantI have rebuilt the my Yocto/Linux and now I do have “crt1.o”, “crti.o”, and “crtbegin.o”.
They are located within
/opt/fsl-imx-x11-4.1.15/sysroots/cortexa9hf-vfp-neon-poky-linux-gnueabi/usr/lib/
but tool says “Toolchain Test Failed”
Tool arguments: -Wl,–start-group “/tmp/VisualGDB_ToolchainTestProgram.o” -o “/tmp/VisualGDB_ToolchainTestProgram” -Wl,-gc-sections -Wl,–end-group
/opt/fsl-imx-x11-4.1.15/sysroots/x86_64-pokysdk-linux/usr/libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/5.2.0/real-ld: cannot find crt1.o: No such file or directory
/opt/fsl-imx-x11-4.1.15/sysroots/x86_64-pokysdk-linux/usr/libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/5.2.0/real-ld: cannot find crti.o: No such file or directory
/opt/fsl-imx-x11-4.1.15/sysroots/x86_64-pokysdk-linux/usr/libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/5.2.0/real-ld: cannot find crtbegin.o: No such file or directory
collect2: error: ld returned 1 exit statusMay 11, 2016 at 17:34 #8209support
Please specify the “–sysroot=<SDKTARGETSYSROOT>” argument in COMMONFLAGS in VisualGDB Project Properties.
You can find more details in our Edison tutorial showing how to configure a similar Windows toolchain. The only difference is that in the Edison tutorial the toolchain runs on Windows and in your case it runs on a remote Linux machine.
May 11, 2016 at 18:39 #8210peter_cz
ParticipantI’d like to have running toolchain on windows as well, but I need to know how. I have toolchain on Linux host.
May 12, 2016 at 00:55 #8211support
Building a Windows toolchain is not straight-forward. We provide basic build instructions here, however it usually never builds out-of-the-box and requires some patching dependent on the compiler version and platform.
We also offer a toolchain building service: you can send us your Linux toolchain and we could build a Windows equivalent. Simply contact our sales with more details to get a quote on that.
May 12, 2016 at 08:41 #8213peter_cz
Participantis there a way somehow to copy it from what is already built on my server host instead of Building a Windows toolchain?
May 12, 2016 at 09:06 #8214peter_cz
Participantdid as suggested and got
Tool arguments: -Wl,–start-group “/tmp/VisualGDB_ToolchainTestProgram.o” -o “/tmp/VisualGDB_ToolchainTestProgram” -Wl,-gc-sections –sysroot=/opt/fsl-imx-x11-4.1.15/sysroots/cortexa9hf-vfp-neon-poky-linux-gnueabi -Wl,–end-group
/opt/fsl-imx-x11-4.1.15/sysroots/x86_64-pokysdk-linux/usr/libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/5.2.0/real-ld: error: /tmp/VisualGDB_ToolchainTestProgram uses VFP register arguments, /tmp/VisualGDB_ToolchainTestProgram.o does not
/opt/fsl-imx-x11-4.1.15/sysroots/x86_64-pokysdk-linux/usr/libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/5.2.0/real-ld: failed to merge target specific data of file /tmp/VisualGDB_ToolchainTestProgram.o
collect2: error: ld returned 1 exit status-
This reply was modified 10 years, 4 months ago by
peter_cz.
May 14, 2016 at 09:15 #8216peter_cz
ParticipantHello,
I’d like to move forward with this issue, can you help me?
collect2: error: ld returned 1 exit statusThanks.
May 14, 2016 at 22:14 #8218support
Sorry for the late reply. The error you are observing happens because some parts of the code are built with the “hard float” ABI and others with “soft float”.
You can resolve this by adding the following flags to COMMONFLAGS:
-march=armv7-a -mfloat-abi=hard -mfpu=neon -mtune=cortex-a9May 16, 2016 at 08:31 #8220peter_cz
ParticipantThanks for your help. Now it seems can compile and my test program resides on host. and I can’t debug it:
gdbserver is missing on “192.168.0.100” (target).
So now I am looking for a way how to get gbserver running on target.
Second question is about configuration and since compiled program resides at host
VisualGDB: Run “make CONFIG=Debug” in directory “/tmp/VisualGDB/c/Data/Projects/Vision_iMX/vc_projects/LinuxProject1/LinuxProject1” on “userbanme”@10.171.88.187 (SSH) but I’d like to have on my target machine. Is it possible have that “automatically” donwloaded to my target machine?
May 16, 2016 at 14:30 #8221peter_cz
ParticipantI did installed gdbserver on my target, I got “Failed to start GDB server session” error message
(gdb begin)
Your VisualGDB trial expires in 28 days!
/opt/fsl-image-4.1.15-debug/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-gdb –interpreter mi –args “/tmp/VisualGDB/c/Data/Projects/Vision_iMX/vc_projects/LinuxProject1/LinuxProject1/Debug/LinuxProject1″
=thread-group-added,id=”i1″
~”GNU gdb (GDB) 7.9.1\n”
~”Copyright (C) 2015 Free Software Foundation, Inc.\n”
-gdb-version
~”This GDB was configured as \”–host=x86_64-pokysdk-linux –target=arm-poky-linux-gnueabi\”.\nType \”show configuration\” for configuration details.”
~”For help, type \”help\”.\n”
~”Reading symbols from /tmp/VisualGDB/c/Data/Projects/Vision_iMX/vc_projects/LinuxProject1/LinuxProject1/Debug/LinuxProject1…”
~”done.\n”
^done
-list-features
^done,features=[“frozen-varobjs”,”pending-breakpoints”,”thread-info”,”data-read-memory-bytes”,”breakpoint-notifications”,”ada-task-info”,”language-option”,”info-gdb-mi-command”,”undefined-command-error-code”,”exec-run-start-option”,”python”]
^done
-gdb-set print demangle off
^done
-break-insert -f main
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x00010734″,func=”main(int, char**)”,file=”LinuxProject1.cpp”,fullname=”/tmp/VisualGDB/c/Data/Projects/Vision_iMX/vc_projects/LinuxProject1/LinuxProject1/LinuxProject1.cpp”,line=”7″,thread-groups=[“i1″],times=”0″,original-location=”main”}
-gdb-set solib-search-path /tmp/VisualGDB/c/Data/Projects/Vision_iMX/vc_projects/LinuxProject1/LinuxProject1/Debug
^done
-gdb-show sysroot
^done
-gdb-show debug-file-directory
^done,value=”/opt/fsl-imx-x11/4.1.15-1.1.1/sysroots/x86_64-pokysdk-linux/usr/lib/arm-poky-linux-gnueabi/debug”
-target-select remote 192.168.0.100:2000
^error,msg=”192.168.0.100:2000: Connection timed out.”
info target
&”info target\n”
~”Symbols from \”/tmp/VisualGDB/c/Data/Projects/Vision_iMX/vc_projects/LinuxProject1/LinuxProject1/Debug/LinuxProject1\”.\n”
~”Local exec file:\n”
~”\t`/tmp/VisualGDB/c/Data/Projects/Vision_iMX/vc_projects/LinuxProject1/LinuxProject1/Debug/LinuxProject1′, file type elf32-littlearm.\n”
~”\tEntry point: 0x105fc\n”
~”\t0x00010134 – 0x0001014d is .interp\n”
~”\t0x00010150 – 0x00010170 is .note.ABI-tag\n”
~”\t0x00010170 – 0x00010194 is .note.gnu.build-id\n”
~”\t0x00010194 – 0x000101dc is .gnu.hash\n”
~”\t0x000101dc – 0x000102cc is .dynsym\n”
~”\t0x000102cc – 0x0001048a is .dynstr\n”
~”\t0x0001048a – 0x000104a8 is .gnu.version\n”
~”\t0x000104a8 – 0x00010518 is .gnu.version_r\n”
~”\t0x00010518 – 0x00010528 is .rel.dyn\n”
~”\t0x00010528 – 0x00010570 is .rel.plt\n”
~”\t0x00010570 – 0x0001057c is .init\n”
~”\t0x0001057c – 0x000105fc is .plt\n”
~”\t0x000105fc – 0x00010864 is .text\n”
~”\t0x00010864 – 0x0001086c is .fini\n”
~”\t0x0001086c – 0x0001087c is .rodata\n”
~”\t0x0001087c – 0x00010888 is .ARM.extab\n”
~”\t0x00010888 – 0x000108a0 is .ARM.exidx\n”
~”\t0x000108a0 – 0x000108a4 is .eh_frame\n”
~”\t0x000208a4 – 0x000208ac is .init_array\n”
~”\t0x000208ac – 0x000208b0 is .fini_array\n”
~”\t0x000208b0 – 0x000208b4 is .jcr\n”
~”\t0x000208b4 – 0x000209bc is .dynamic\n”
~”\t0x000209bc – 0x000209f0 is .got\n”
~”\t0x000209f0 – 0x000209f4 is .data\n”
~”\t0x000209f4 – 0x00020a88 is .bss\n”
^done
-exec-continue
^error,msg=”The program is not being run.”
— GDBServer output —
Process /home/root/LinuxProject1 created; pid = 559Listening on port 2000
May 16, 2016 at 15:43 #8222peter_cz
Participantreading your tutorial I can’t get behavior
http://visualgdb.com/tutorials/linux/edison/
@ step 13. I can’t get output to “gdbserver” window is not started and code does not enter debug mode.
May 17, 2016 at 05:46 #8224support
Normally VisualGDB will automatically deploy everything when you start debugging.
If GDB reports the “Connection timed out.” error, most likely either the gdbserver failed to initialize properly, or your firewall is blocking the connection. Does the gdbserver window in Visual Studio show any errors, or is it reporting a successfully opened socket on port 2000?
May 17, 2016 at 07:49 #8225peter_cz
ParticipantAfter I do right click and from context menu choose Debug -> Start New Instance then I got dialog “Select Process to attach debugger to” then Debugging failed whatever process I choose.
Otherwise not selecting a process i have almost nothing happening but within VisualGDB Program Output it’s displayed
Listening on port 2000And really nothing is happening, no debug, debugger is not started and no stepping thru the code etc…
May 17, 2016 at 16:57 #8229support
KeymasterIf VisualGDB asks for a process to attach, it means that your debug settings have “Attach to a process” selected. Please open VisualGDB Project Properties and change gdb launch mode to “Debug a new instance”. This should resolve the problem.
May 17, 2016 at 17:11 #8231peter_cz
Participant(gdb begin)
-gdb-version
~”done.\n”
^done
-list-features
^done
^done
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x00010794″,func=”main(int, char**)”,file=”LinuxProject1.cpp”,fullname=”/tmp/VisualGDB/c/Data/Projects/Vision_iMX/vc_projects/LinuxProject1/LinuxProject1/LinuxProject1.cpp”,line=”8″,thread-groups=[“i1″],times=”0″,original-location=”main”}
^done
-gdb-show sysroot
^done
000-data-evaluate-expression 0
000^done,value=”0″
info target
&”info target\n”
~”\tEntry point: 0x1065c\n”
~”\t0x00010194 – 0x000101e4 is .gnu.hash\n”
~”\t0x000101e4 – 0x000102f4 is .dynsym\n”
~”\t0x000102f4 – 0x000104be is .dynstr\n”
~”\t0x000104be – 0x000104e0 is .gnu.version\n”
~”\t0x000104e0 – 0x00010550 is .gnu.version_r\n”
~”\t0x00010550 – 0x00010560 is .rel.dyn\n”
~”\t0x00010560 – 0x000105b8 is .rel.plt\n”
~”\t0x000105b8 – 0x000105c4 is .init\n”
~”\t0x000105c4 – 0x0001065c is .plt\n”
~”\t0x0001065c – 0x0001098c is .text\n”
~”\t0x0001098c – 0x00010994 is .fini\n”
~”\t0x00010994 – 0x000109ec is .rodata\n”
~”\t0x000109ec – 0x000109f8 is .ARM.extab\n”
~”\t0x000109f8 – 0x00010a10 is .ARM.exidx\n”
~”\t0x00010a10 – 0x00010a14 is .eh_frame\n”
~”\t0x00020a14 – 0x00020a1c is .init_array\n”
~”\t0x00020a1c – 0x00020a20 is .fini_array\n”
~”\t0x00020a20 – 0x00020a24 is .jcr\n”
~”\t0x00020a24 – 0x00020b2c is .dynamic\n”
~”\t0x00020b2c – 0x00020b68 is .got\n”
~”\t0x00020b68 – 0x00020b6c is .data\n”
~”\t0x00020b6c – 0x00020c00 is .bss\n”
^done
-exec-continue
Process /home/root/LinuxProject1 created; pid = 602Listening on port 2000
