XMC4500 byte alignment
Sysprogs forums › Forums › VisualGDB › XMC4500 byte alignment
  • #12448
    lkormos
    I have a XMC4500 custom board and a working code witch was created under DAVE eclipse softver.
    I build my project under VisualGDB, but it is not working perfectly becouse of packed structures. I tried adding “-fpack-struct” to flags, but i got hard fault when the program trying to access hardware registers (-fpack-struct=4 is working fine, but i need byte alignment).
    Is there any solution?
    Regards,
    Kormos L.
    #12458
    Yes, please try setting __attribute__((packed(number)) on the specific structures that need to be packed.
    You can also try this build [http://sysprogs.com/files/tmp/VisualGDB-5.3.8.1797.msi]. Once you click ‘details’ in the embedded memory explorer, it will show struct sizes and field offsets directly in the code.
